I was playing Xbox on my 32" vizio flat screen TV when all of a sudden the whole screen turned green for 3 seconds and then went away. It is a new TV and I had only been playing for an hour and 30 minutes. After 10 seconds it continued to turn green every 3 seconds. The whole screen glitches green, red, and yellow. Also when I play Xbox the screen freezes. I am very frustrated and would greatly appreciate it if you can help me.
  • 2985 Answers
SOURCE: Half of the screen is black and doesn't display the picture
Send it back this appears to be a major failure
Posted on Oct 20, 2007
SOURCE: TV Powers off after 30-45 mins
I had the same problem with my 1 year old 26" TV. I called Magnavox customer service, and they had me upload a new software driver to the TV - which didn't solve the problem. Then they suggested that I call the local Authorized Service Center - and they estimated that it would cost $200+ to fix the problem. But then I found the "remove the back solution" listed here - and it worked!
Thanks, you saved me at least $200.
Posted on Jul 20, 2009
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
  • 8457 Answers
SOURCE: I purchased a Vizio 32'
This tv have the main Tuner signal board have intermitten problems.Return this tv for a refund.Can't return it make a claim with Ebay,Pay PAL or ur credit card if pay by credit cards.
Posted on May 12, 2011
I purchased a Vizio 32' VA320M off of ebay and it arrived today, I hooked it up watched it for a couple hours this morning, played a little xbox on it and went to sleep. I woke up tonight and was...
May 12, 2011 | Vizio L32 32 in. LCD HDTV
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio 42 LCD
2 days agao my reds went away,,everything is all green,,already checked everything,,wires,settings,,reset,,all that,,what can be the deal ?
Aug 11, 2008 | Vizio L32 32 in. LCD HDTV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Green Screen
my screen is green.  i can hear audio but no picture.
Jan 17, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Nov 27, 2007 | Vizio L37 Television
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
