Question about Symbol P370 Wireless Barcode Scanner
Scanner won't scan barcodes to app - Symbol P370 Wireless Barcode Scanner
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
  • 74 Answers
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Posted on Oct 23, 2009
  • 38 Answers
SOURCE: Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Posted on Jan 06, 2010
Yogger
  • 117 Answers
SOURCE: Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Posted on Dec 07, 2010
How do i get my iphone to scan barcodes
You either have to download a barcode reader app OR purchase a Bluetooth barcode scanner and pair it to your phone. Please contact us for more info at 888-317-3440
Why Choose BCTP Our focus is on Service and Support
Jan 10, 2016 | Computers & Internet
Camera won't scan barcode
Which barcode scanner app are you using? You could try using a different app if the one you have won't work.
Mar 22, 2014 | Kyocera Rise Sprint
Bar code
I know alot of apps for scanners.. but it depends on how and what ur scanning and database ur using. Ill give u a good resource to assist with this,
If further questions ill follow this
chadman
http://youtu.be/_CBxWO6fmek
Dec 18, 2013 | Adesso NuScan 2100U Wired Handheld Barcode...
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Aug 04, 2011 | Zebra Symbol Technologies MC909X-G Series...
Have a VB app for Symbol MC1000 barcode scanner that has worked for about a year. Recently, scanner brought to IT dept since app no longer runs. Error is "Cannot find app_name (or one of its components)....
I had a similar problem on an MC75.
I had a back up of the registry, so I restored the backed up registry and it all started to work again.
Hope this helps!
Netty
Sep 09, 2009 | Symbol Computers & Internet
My mc9090-g doesn't scan any barcodes
you can download MS active sync from microsoft website. then connect the gun to your computer to sync it. Once it sync, drag the barcode app to the windows folder in the gun.
Dec 02, 2008 | Symbol MC9090-G Barcode Scanner
Barcode scanner keeps reverting to internal utility
You could delete this utility if you are not using it
Jul 29, 2008 | Symbol MC50 Pocket PC
PDT6842 simple scanning app
GO INTO YOUR BUILDHEX.BAT FILE AND ENABLE THE BAR CODES THEN HIT ESC. THEN S TO SAVE THEN RELOAD YOUR SCANNER. THIS IS THE FILE YOU MAKE ALL YOUR CHANGES TO.
Nov 21, 2007 | Symbol PDT6842-NIS632EU Portable Data...
Symbol P370 Wireless Barcode Scanner Logo
52 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
