Question about Sony VPL-FX40 Projector
Sony vpl FX40 on/standby light blinkng red - Sony VPL-FX40 Projector
Marrie
  • 563 Answers
SOURCE: SOny VPL-EX1 turns on for a few minutes and then the Lamp /Cover LED and Power ON/Standby LED flashes.
Hi David
I think you should replace the lamp.
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
SOURCE: Sony VPL HS 1 will not start after a power cut,
Try cleaning out the filter. There may be a heat protection mechanism in there. We had much less problems after cleaning (or replacing the dust filter).
Posted on Mar 08, 2010
omtronixom
  • 172 Answers
SOURCE: Our Sony VPL-EX4 Projector keeps shutting itself
Check fan cable
Posted on Aug 11, 2010
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
light is in red means standby mode.
Flashes in red - The projector is in abnormal status. Symptoms are indicated by
number of flashes. Address the problem in accordance with the
following. If a symptom persists, despite having taken measures below, consult with qualified Sony personnel.
Dec 04, 2015 | Sony Office Equipment & Supplies
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Jun 23, 2015 | Sony VPL-ES4 Projector
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
I have a problem with the Sony VPL-CS3 Projector, in which it doesn't light up and the Lamp/Cover light is blinking orange while the On/Standby light is blinking red, and I don't have the remote as...
The lamp cover has a safety interlock device so the unit will not come on if the cover is missing, maybe the safety interlock is faulty or the part of the cover that engages the safety has come away. Other than that I'm not sure what the poblem would be. That is were I would start.
Good luck
Aug 10, 2011 | Sony VPL CS3 Multimedia Projector
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
Not producing any image
check the Lamp unit. If Lamp is ok then check the ballast unit
Mar 10, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
Sony VPL-FX40 Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
