Question about Maytag Ovens
Double oven hinge replacement - Maytag Ovens
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Posted on Feb 08, 2009
barkencoa
  • 3463 Answers
SOURCE: hinge broken on baumatic double oven door can it
Hi.
Yes it can, no ptob, but you will need to replace the pair, otherwise it will not close properly.
POlerase rate my solution.,
Thanks.
Posted on Jul 16, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Posted on Nov 07, 2009
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
Replace the oven door hinge
Here's a link with the info on how to replace a hinge on a similar model--schematics for both are virtually identical--this link contains some images that should help along the way:
http://www.managemylife.com/mmh/questions/164631-how-do-i-change-the-oven-hinge-on-my-ge-jb960bb2bb
Jul 16, 2010 | GE Profile JTP56 Electric Double Oven
Oven door not sealing properly and heat escaping
Check the hinges at the bottom corners to see if the spring is still connected and see if the hinge is wore out. The door lifts off the hinge when it's in the partially open position after loosening the screw holding the door in position on the hinge. Slide the oven out a little to access the hinge to replace or inspect.
Jan 01, 2010 | Neff U1421 Double circotherm Electric Oven
Top oven door will not close..appears left hinge not working
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Dec 15, 2009 | GE Profile JTP56 Electric Double Oven
If you got to:
www.youtube.com
Thanks.
Feb 07, 2009 | Baumatic B720 Electric Double Oven
My oven door will not shut tightly
Hi, I take it that this a whirlpool oven? Single or double oven? If it is a double your in luck! Your door hinges need replacing along with the inserts that are located inside the oven cavity. You can exchange the hinges and inserts from the oven doors and hinges if you have a double oven. If not get some new ones and fit them in! Easy job you will just need a little guidence as some models do differ..
Get back to me if this is usefull.....
Dec 30, 2008 | Whirlpool Ovens
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
