Question about Panasonic SC-PM27 CD Shelf System
Hi I have a panasonic SA-PM27 stereo system which was knocked off a shelf now it shows the error code F61 of course it doesnt go.
5 Suggested Answers
SOURCE: F61 error
whats wrong is that whilst the power amplifier is running and the system fan fails due to internal resistance of the fans resistor the main power amplifier overheats causing the main power NPN transistors to turn off the system power by the use of a logic AND gate that causes the error code F61 to appear and turn off the systems power supply. The solution is simple the main transistors are removed carefully and their terminals are shorted using a screw driver. the transistors contains a little voltage which activates the AND gate to shut off the power supply and the error F61 appears. make sure the transistors are replaced correctly and solder very light. If the problem still occurs provided that all transistors are fully shorted(all three terminals) and properly replaced then the radio should be taken to a professional
Posted on May 23, 2008
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
SOURCE: F61 code error
I had this problem! Panasonic 5CD Hi Fi. I opened the case to get a look at the circuits and noticed a covering of dust on the components. I took the hoover to it and an initial inspection could find no glaring problems, such as burnt PCB! I decided to power-up and to my joy the machine whizzed into life. Problem solved!!!!!!!! BTW, this unit is at aprox 10 years old and still goin great!
Posted on Oct 09, 2009
pjbaldi
  • 8 Answers
SOURCE: How to fix F61 error?
First re solder any dry joints on Transistors Q502, 504, 507, 515 & CN500, IC501. If there are no dry joins replace IC501 (STK470-0??) & maybe D501 (16.V) zener
Posted on Feb 26, 2010
How do i fix an error code f61 for sa ak40 panasonic stereo
There is most likely a short in the amp that needs to be repaired.
Mar 13, 2013 | Audio Players & Recorders
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
I got panasonic- sa-ak240 stereo system i get F61 on the display then it shuts down to standbye.
F61 is an Error Code......it's basically indicating that something inside the stereo is malfunctioning or broken.
the stereo has gone into Protection mode.....could mean there is Direct Current on one of the output rails....most likely the Power Amplifier IC in your Stereo has gone bad....a new one should solve this problem....you'll need to send it in to Panasonic for replacement of the faulty parts.
Oct 28, 2010 | Panasonic SC-AK240 Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic SC-PM27 CD Shelf System Logo
89 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
