Question about Ectaco Office Equipment & Supplies
I can no write a new word to be translet
I need most explanation about external features
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
Translet to english
There is a handy translation service on line called 'Bablefish'
Just google bablefish
Apr 25, 2011 | Computers & Internet
I have a Western Digital 160 G (WD1600U017) external drive. When I plug it in the USB slot, my computer can't seem to locate it and no letter is assign to it to access this hard drive. At one point I got...
AS long as the computer device drivers are up to data, the USB port should be operational and communicate with your external drive. If the external drive is connected to a USB port and you are certain the external drive is running (listen for the whirring sounds) and still no communication; the hard drive may have lost the formatting feature. Switch USB ports around and see if any signal reaches the File Explorer in Windows.
Feb 17, 2018 | Western Digital Caviar WD1600 (1600YD) 160...
While setting up speed dials, I press Feature *4, then "hold or release" shows up on the screen along with a beep.
Hi The code you need is Feature *1 for external calls, Feature *2 for internal calls Feature *3 for functions.
F*4 is 'Call Forward'
If you Press Feature *0 then press each button in turn it will show you what is under that key (Button)
If you are setting up external calls you may have to pre-fix every No; with a 9 . if you are in 'Pool Group' working.
Hope this helps
Aug 09, 2010 | NorStar T7208 Corded Phone
Plis help mi norwgian to amharic transleter or
Unfortunately, it doesn't look like there are any Amharic- Norwegian dictionaries or translators.
Here are some free lessons I found that will help a Norwegian speaker learn Amharic though: http://www.internetpolyglot.com/lessons-am-no
You could also use a Norwegian- English dictionary/translator and then an English-Amharic one. I know it's not ideal, but it looks like that's your best bet.
Here is a free online English-Amharic dictionary: http://www.amharicdictionary.com/2.0/Default.aspx
Here are a few free English-Norwegian dictionaries:
http://www.freedict.com/onldict/nor.html
http://www.tritrans.net/
and a free translator: http://www.translation-guide.com/free_online_translators.php?from=Norwegian&to=English
I hope this helps, and I'm sorry again that there isn't a better solution for you.
Let us know if you have other questions.
May 31, 2010 | Acer Computers & Internet
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
How do I change the number on a speed dial
You can program a memory button with a new number or
feature.
External autodial:
1. Press (Feature), ( * ), (#1).
2. Press a memory button.
3. Dial the external number.
4. Press OK to store the number.
Internal autodial:
1. Press (Feature), ( * ), (#2).
3. Dial the extension number.
How to erase memory buttons:
3. Press OK to erase the button.
Alternatively, you can download the Nortel T7316 Quick Reference Card from IdacomUSA, your solution for Nortel Repair and Refurbishing.
Feb 11, 2010 | NorStar T7316E Corded Phone
Can you record a playing vhs video to a dvd on sharp dv rw250?
Yes, you can do this if you have a VCR that has a channel on the VHS part of the unit that shows your DVD screen (see instruction manual for better explanation). The Sharp unit that you have might have this feature, if not then look at your instruction manual for how to hook up the VCR part of your unit to an external DVD player. Good luck to you!
Nov 04, 2009 | Sharp DVRW250 DVD Players
I have had a new fuel pump put in my car and now my check engine light is on and I had a test done at Autozone and the explanation states BBInertia switch tripped or open, what needs to be done?
well the inertia switch is a safty feature that shuts the fuel pump off when the vehicle is in a accident. you are gonna have to replace that or reset if possible.
Oct 21, 2009 | 2003 Ford Taurus
Retrieving data off an external hard drive
You can and there is no need to install drivers, except the drive has any special features.
Apr 19, 2009 | Computers & Internet
53 people viewed this question
Top Ectaco Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
tony wahlman
tony wahlman
Are you an Ectaco Office Equipment and Supply Expert? Answer questions, earn points and help others
