Craftsman Woodstock Percussion Crcbm  Chime, Black Medium
Problem for Craftsman Woodstock Percussion Crcbm Chime, Black Medium
I recentley bought a Craftsman 4.0 HP mower at a
By loueye66 on Jun 09, 2009
I recentley bought a Craftsman 4.0 HP mower at a yard sale, tested it before taking home and it fired right up. It did run a little rough so I replaced the air filter & spark-plug. Once again it fired right up and cut my lawn beutifully. The other day I went to mow the lawn and now it starts but dies after a couple of seconds. I've checked hose connections as well as the spark-plug connection. I'm stumped
Best Solution
posted on Jun 09, 2009
Helpful)
#1 Taper
Rank: Guru  Garden Tools  Expert
Rating: 88%, 304 votes
You need to disassemble the carburetor and spray the with carb. cleaner. Make sure all small debris is out. Ckeck any gaskets for signs of ware. If they look bad, replace them; your carb. could be sucking air if so. Also check the fuel filter to see if gas is flowing through it.
Jim
Comments:
Jun 13, 2009
- Did this solution solve the problem?
Jim
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 18, 2009
Not Rated)
ed in oregon
Rank: Guru
Rating: 87%, 60 votes
it would be helpful to know which brand of engine you have, but here goes - if it is a tecumseh, remove the little brass "nut" that holds the float bowl on, it will have a hole by the hex part, a hole from the top going straight through, and a tiny, tiny hole at the top edge of the threads, clean these out with a small piece of wire brush - if briggs with independent carb, remove the "nut" and clean the two holes - if briggs with carb mounted to gas tank, remove the carb/tank assembly, remove carb, replace the diaphragm
Was this helpful?
Yes
No
Popular Solutions for Craftsman Woodstock Percussion
Questions and Unsolved Problems for Craftsman Woodstock Percussion
Do you recommend Craftsman Woodstock Percussion Crcbm Chime, Black Medium?
Answer
Answer
Replace auger on a snowblower
Answer
I have a 25 ton yard machine log splitter and the 1/2 inch pipe from the ram to the hand control... (More)
Answer
are there any crews that are hiring in the greater cincinnati area
Answer
repair for blanchard grinder motor bearing replacement.
Answer
Schematic for replacing the clutch in a POulan Pro 300E electric chain saw? How is it replaced?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Power Lawn Mower Experts
Top Garden & Power Tool Repairmen
in , IL
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
