Question about Canon Office Equipment & Supplies
Replace black cartridge om Canon MX394 and color cartridge is missing get error code 1401 COL do i need the empty cartridge in
Replace black ink but color cartridge is missing can not find it
SOURCE: My Canon Pixma MP220 is
Same thing happened to my MP220. U051 chk Blk and Colour. I got my colour one replaced as there was an electrical fault in it. So the solution is to replace whichever one has the electrical fault or both and it works just fine. Refilling only works for a certain number of times. 4 or 5 at most and mine only lasted 1, so not always successful.
Posted on Feb 18, 2009
SOURCE: Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
Posted on Apr 16, 2009
SOURCE: Get error: check ink u059 col
For me, this meant that I put it an ink cartridge that wasn't compatible.
Posted on Jun 16, 2009
  • 17 Answers
SOURCE: Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Posted on Feb 18, 2010
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
Ink printer cartridge replacement
The error code you have 1401 shows 'There is no print head installed' With the printer turned off and unplugged: Remove the printer cartridges. Check to make sure the contact points are clean and do not have something covering them. Look inside the printer and check the cartridge bay for any debris or dust blocking the connection. If anything is found clean gently with a q-tip or cloth. Do not touch the contacts with your fingers. Reinsert the cartridge and power on the printer. If the same error code displays return the print cartridges for a replacement as they may be defective. Most cartridges have a chip on them that communicates with the printer. If the chip is missing, damaged it will not work. As always only use manufacturer recommend cartridges.
Dec 01, 2013 | Canon Office Equipment & Supplies
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
Canon mp270 error code 5200
Hello and WelcomeError 5200 is a service error. Follow this solution step by step
  1. With the printer turned on,unplug it
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs if it was helpful. Thank you for using FixYa
Mar 10, 2011 | Canon Pixma MP270 All-in-One InkJet...
Color cartridge recognition MP160
E5
5 times
The ink cartridges are not installed [1401], or a non-supported ink cartridge is installed [1485], or the ink cartridges are not installed properly [1687].
Check if supported ink tank(s) is installed, and re-install them properly, and then close the scanning unit.
Sep 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Canon mx 310 alarm color cartridge empty
Go to the printer driver (control panel -> Printer -> Right Click your Printer -> Properties). From there go to maintenance tab, Ink Cartridges, Select Black only. Then click OK. Finally hold the Stop/ Reset button for 10 secs or so. It will then work after a couple of warnings.
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Help with error 1401
To print without color ink go to START>control panel>PRINTERS & OTHER HARDWARES>PRINTERS & FAXES>Right click to your printer>PROPERTIES>MAINTAINANCE>INK CARTRIDGE SETTING>then select BLACK ONLY.
I think it fix your problem.
Nov 13, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Error Message V163
well col probably stands for color.....i would try unplugging your printer for 10 seconds then plugging it back in....that resets the printers memory. did you buy the right black ink cartridge? that might throw a error code.
Sep 22, 2008 | Canon PIXMA MX310 All-In-One Printer
70 people viewed this question
old marine
old marine
