Question about Samsung Televison & Video
I finall got the optical fiber cable to hook up the Samsung Crystal Surround Ait Track, model HW-FM35. It works great BUT, it shuts off after apprx 15-20 mins. Help?
pattersj78
  • 70 Answers
SOURCE: No sound when connecting with a fiber optic.
have you tried a new cable?
Posted on Oct 27, 2007
simplemitch
  • 752 Answers
SOURCE: Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Posted on Dec 18, 2007
tech48
  • 624 Answers
SOURCE: I have a JVC rx-6032v
yes, you must use the setup menu and assign the optical input to the input you are using. Some receivers have a "input mode" switch. If this one does, you only ned to press it until it says "optical". If you have a owners manual, it will decribe all the settings that need to be made to accomplish what you need.
If you do not have one, I have uploaded one to my website for you do have. It will only be there for a limited time before I remove it, so get it quickly. You need Adobe Reader to read this, so if you don't already have iton your computer you can download it free here:
http://www.adobe.com
Here is the link to the owners manual:
http://www.get1here.net/rx-6032v-ownersmanual.pdf
I would appreciate a "FixYa!" rating for this free information and manual. Let me know if I can be of any further help.
Dave
Posted on Jul 12, 2008
tech48
  • 624 Answers
SOURCE: I hooked up a fiber
Make sure that the place it is plugged into the TV is an output and not an input for the fiber optic cable, and the place it is plugged into the Onkyo is an input and an output for the fiber optic cable. This can be connected backwards very easy. Then you want to make sure that the Onkyo is properly set on the right function to listen to the TV. Check your owners manual on how to set up the optical input and have it assigned to the function you are trying to use. Sometimes these type of receivers have an input mode button that you can set to "optical" or "analog" or "digital" or "auto". Try changing those settings after you make sure the TV optical is an "OUTPUT" and the optical on the Onkyo is a "INPUT".
After you have these thing set right you should be able to listen to it like this.
I hope this helps, if you need more help just reply back on this post, but please give more detail about the connectors and on the TV and the Onkyo, and about the digital input settings on the Onkyo. It would also help to know the model numbers of both the TV and the receiver. There is no way to check out what each of your devices are capable of doing without knowing the model numbers to look up the specs.
Thanks,
Dave
Posted on Sep 07, 2008
  • 34 Answers
SOURCE: problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 06, 2008
How could i hook up my hw-f350-355 to my samsung no sound
http://www.samsung.com/ie/support/model/HW-E350/XU-downloads?downloadName=UM
This Samsung weblink for will allow you to download the manual for your product in .pdf format. See page 12 for HDMI ARC connection, page 13, for analog connection.
Did you turn on the power button? Happens all the time.
Dec 01, 2013 | Samsung HW-E350 Crystal Surround Air Track...
Samsung HW-FM45C 280W Soundbar with Wireless Subwoofer and HDMI Cable Samsung Users Manuals
Samsung HW-FM45C Crystal Surround Air Track (Active Speaker System) User Manual:
copy and paste this link in your internet browser to see:
http://downloadcenter.samsung.com/content/UM/201410/20141007150930882/[HW-FM45C-FM45-ZA]AH68-02647A-08ENG-1006.pdf
Nov 17, 2013 | Cell Phones
How do i hook up a dvd player to the samsung surround air track
Would have to use the optical cable probably. There are also analog rca connectors on the soundbar, but a lot of dvd players don't have rca outputs.
Sep 19, 2013 | Samsung HW-D450 Crystal Surround Air Track...
HW-e550 connection
If you have a newer tv with an optical audio output, that would be the easiest way to hook it up. Leave your current setup alone, and just hook an optical cable from the tv to the sub.
Apr 02, 2013 | Samsung HW-E550 Crystal Surround Air Track...
Have hooked up system according to manual (I think) using HDMI, to Samsung plasma set. Also have audio cable hooked up (from subwoofer to tv). Get absolutely no sound through system. I imagine I have...
Look on the back of your TV for an HDMI port that has "ARC" on it, connect that to the HDMI Out on the subwoofer. Make sure that your HDMI cable supports ARC. That is the only connection you should need to the subwoofer, remove everything else. Other option is an optical cable between the TV and the Subwoofer.
I just discovered this after fooling around with it for the past couple of days!
Dec 27, 2012 | Samsung HW-E550 Crystal Surround Air Track...
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Televison & Video Logo
11 people viewed this question
Jerry Greenberg
Jerry Greenberg
