Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How do i adjust the leveling legs whirlpool cabrio
2 Suggested Answers
SOURCE: Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Posted on Jul 10, 2011
Leak at left side and front of lid model #8240ywo
Be sure and check if the flooring is in good straight flat surfaced,if it is,then re tighten all the screws/bolts around its body and it`s back,then put level bar on top of it,if it is not leveled properly,re adjust/turn the four legs of unit until you achieve the dead zero level on your level bar.
Oct 25, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a whirlpool cabrio model wtw6600sw0 ans my washer tub is unbalanced and rocks bad. i have leveled the machine and evenly distributed the load! could there be something wrong with the tub or...
after you leveled the washer did you turn the locking nuts on the legs up against the bottom of the washer cabinet to keep the legs from vibrating back out of level?if you dont lock them they will change height during spin
May 06, 2012 | Washing Machines
My cabrio makes to much noise wen spin
Washer might not be level. Use a level on the top and side to confirm. See user manual if adjustments are needed.
Oct 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
This is a joke. have a simple question & have to pay. just wanted to know how to adjust back leg on a whirlpool thin twin.
the back legs tend to get stuck after sitting in one place for so long.use a screwdriver and free both legs so both are down that should free it up so it will pivot and the back legs will automically adjust and level theirself (you will need to screw in/out front legs to adjust them)
Aug 22, 2011 | Whirlpool Washing Machines
Moved my thin twin to clean & the back leg on the
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 1973 whirlpool washer. I am trying to adjust the back legs on it. It appears to have a spring loaded bar between each of the back legs. The back legs are not adjustable and look to be self...
Disconnect ac/cord,hoses and drain pipe, lay machine down on front side. Inspect the self-leveling bar ***'y and spray liberally with WD-40 if rusty and/or stuck.
Feb 22, 2011 | Whirlpool Washing Machines
How do you adjust the rear legs
Try lifting up the back end of the machine so both legs come completely off the ground. They will try to auto level themselves when you put it back down. Most of your adjustment should be done with the front legs though.
Mar 29, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Duet washer is off balance.
My wife and I just purchased the Whirlpool 9400 series washer and dryer. We loved the pair, the installers came in and set them up ran them rather quickly and showed us the features and left. We put our first load into the washer, I will add, it was a rather large load, but nothing bigger than what the washing machine would handle. Started the washer up and walked away. About 30 minutes later we walk back into the laundry room to see and hear the washer rocking the pedastle door right out of the pedastle and then started to walk itself about 12 inches from the wall. This was very dangerous to us as we have a 14mth old. We immediatly called the store who sent another installer over. He again checked it for levelness and said that this is a known issue and that we should consider buying the cabrio or taking the washer and dryer off the pedastles.
So, to solve this issue, I'm sure you are all waiting. Infact, the washer was level, however, and this is what I found to be key, Lift the washing machine off the front legs, raise them up about a 1/4" higher than the back legs, this will make the washer uneven from front to back, but the other key is to make sure that the nut on the washer leg is all the way up and tight against the washer. In my user manual it said use a 17mm open end wrench to lock the nut against the washer, but my nut was a 14mm.
Again, make the front of the washer a little higher than the back and make sure all the nuts that are on the washer legs are tight against the washer or pedastle.
My washer went from the house ********, to the thing that doesn't make any noise at all.
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
