Question about Honeywell Air Purifiers
Honeywell HFD320 electronic filter check will not reset
Changed filter and pre filter both lights continue to blink, not resetting
Hello, this is Ava with Think Crucial.
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jun 18, 2016 | Honeywell Air Purifiers
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Have honeywell air geius 5 can't reset filter lights
Ava B.
Feb 15, 2016 | Honeywell Airgenius 5 Air Cleaner/odor...
How to reset indicator light on air filter
When resetting your Intelli-Check Filter Indicator. the air purifier should be powered on. Press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off.
Ava B.
Feb 15, 2016 | Honeywell Air Purifiers
Resetting Filter status after cleaning filter
MAKE SURE THAT THE LID OF THE FILTER IS PROPERLY CONNECTED SOMETIMES THESE DEVICES ARE
BUILT WITH SWITCH FILTER
Jan 13, 2014 | Honeywell Air Purifiers
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Air Purifiers Logo
505 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
