Grundig Amira 26 LXW Flatscreen TV
When I turn the TV on, it switches itself off immediatley.  If I am prepared to try again and again it eventually will stay on but this is quite frustrating!
Brought this TV just over a year ago and over the past month have been having the problem with increasing frequency.
Any ideas?
  • marin340 Mar 29, 2009
    I have the same problem with Amira, but no solution yet. If somebody helped me with diagnostics, I could replace broken parts myself. I already opened the TV, but visually everything looked OK, only HI-POT condenser smelled a bit. Maybe this Hi-pot pass Rubycon 450V could be the problem? PLEASE, HELP!!!
SOURCE:
  • 6 Answers
SOURCE: Sylvania TV will not come on
if its remote control try pressing no 1 and see if it comes on.alternatively the on and off switch if faulty on th tv,but the remote control should still switch it on.also switch off the tv for 24 hours by completely removing it from the mains and see if that resets it.
ricch
Posted on Sep 13, 2008
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
SOURCE: olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Posted on Jan 20, 2009
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
  • 1214 Answers
SOURCE: TV says no signal from direct tv box
Yes, something could have gotten changed.
Confirm what input connection the DirecTV receiver is connected to on the back of the TV. Using the remote, check that the TV has that input selected.
Grundig Amira 32 LXW 82-7512 no go
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 27, 2014 | Polaroid Televison & Video
Tv pin code
tray -oooo- or 1000 or 1111 if not tray 8500 this is the service cod
Nov 25, 2013 | Televison & Video
How to manually turn the subtitles off on a grundig lenaro tv
Turn subtitles language to... turk... o another language ...Solved problem!
Dec 03, 2012 | Grundig Lenaro 26 in. LCD TV
Lcd problem
Unplugging the television for about fifteen minutes or so, then plugging it in again.
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
May 18, 2006 | Grundig GF70-600 TV
Televison & Video Logo
372 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
