Question about LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher
Dishwasher door tension - LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
HOW TO ADJUST TENSION ON DOOR
Just below dish loading door you will see a panel. Remove screws (if applicable) to remove panel and you will find the door tension adjustment. Turn adjustment usually with a screw driver to the left to loosen or opposite lifting door opened and closed till you are happy with tension.
Jan 31, 2011 | LG LDF6920ST Stainless Steel 24 in....
Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
Jun 03, 2010 | Fisher and Paykel DS602 Dishwasher
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
DOOR TENSION
open the dishwasher and look at the top of the chassis, where the door catch is. You'll see 2 screws with hexagonal heads, one on either side of the catch. Turning these screws will apply or reduce tension on a wire liked to a spring on either side of the door. Tension must be equal on both sides.
Jan 20, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Oct 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher Logo
13 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
