Question about Brother CS-8072 Computerized Sewing Machine
Bobbin winder won"t turn
Machine works great but bobbin winder won't turn
caroldon
  • 17129 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
SOURCE: Brother CS80 ..... bobbin winder
check the power cord to see if it plugged in to the machine correctly
& if it is then something could be loose or broken inside, it needs to be serviced
Posted on Aug 03, 2011
  • 83 Answers
SOURCE: my bobbin winder will not work. I can hear the
Check the belt inside,might had came out or broken.Thank you.
Posted on Sep 16, 2011
ju222dy
  • 8 Answers
SOURCE: Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Posted on Aug 09, 2012
ju222dy
  • 8 Answers
SOURCE: Bobbin winder belt melted
Bobbin winder not working
For ~$30, you can purchase a stand-alone bobbin winder (Sidewinder) that you can use to wind your bobbins. Saves wear-n-tear on your machine and you can wind bobbins without unthreading your machine. Just be sure to verify your bobbins are compatible with the Sidewinder.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Bobbin Winder
Jul 18, 2017 | Sewing Machines
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Jun 05, 2017 | Janome Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-8072 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
