Question about Dometic Refrigerators
Whistling noise What is the whistling sound coming from back of refridg? This is our 4th RV with Dometic, and this is the first time we have heard that noise.
    Top Expert:
  • Dometic Master
  • 5,743 Answers
Cooling fan
Posted on May 27, 2016
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: I have a rv with the Dometic RM2852 refridg. It
First thing to check is that the control switches are in the proper position, since some RV fridges require a particular placement for the fridge to operate on different power souces.
Check your owner's manual for troubleshooting steps for your specific fridge, beyond that, here's link to a site that provides a step-by-step troubleshooting guide complete with active links for each potential issue.
http://gasrefrigeration.net/works_on_gas_but_does_not_work_o.htm
Here's a copy of the manual for your fridge model that you can download and print for free, just in case you don't have yours handy.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you found this very helpful and best regards!
Posted on Aug 08, 2009
  • 332 Answers
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Posted on Mar 08, 2010
sonicboomele
  • 1557 Answers
SOURCE: how do I remove the door on a dometic 1292 RV
peel back the rubbers and you will see screws undo then and the plastic door ligning will come of with the seal taske of old put on new and replace in reverse
Posted on May 15, 2010
male_28_cam
  • 1555 Answers
SOURCE: My Dometic RV refridge will
it does sound like you are losing voltage to the refrigerator. A volt meter will need to be used to see where your bad connection is located. Inspect connections from lower board to upper control panel also. First measure the voltage on the commercial power wether you are getting 110 V or not then proceed further till you have located the bad connection.
Posted on Jan 23, 2011
I have a rv with the Dometic RM2852 refridg. It works fine on gas, but when I switch to AC input the gas turns off like normally should but the refridg does not cool. The Auto light is on, 120VAC is OK at...
Aug 08, 2009 | Dometic Refrigerators
Dometic rv air conditioner over 100 deg. trips breaker.
The problem is that when u add up the electrical draw from all of these appliances running full bore, your draw exceeds your available amperage. Now you are doing the math and saying no...... Let me tell you why. It is rare to find a situation where a 100 amp service actually porovides 100 amps. You almost always have voltage dropo. And when you are adding extension cords to the mix the drop is even more. That said, When you are using the AC try to minimize the use of other appliances, especially the microwave which is a big draw too.
Jun 25, 2009 | Dometic Rooftop RV Air Conditioner
Good 2500w generator and my r/v Dometic 13,500 a/c.
The 2500w gen. is good for approxiamtly 20a. so, you have to look at the initial draw on start up of a\c, ur 13.5k unit will pull around 10amps under load. Refridge, pulls probably 10a. so, there's the math of it. Check around on my figures, I'm not always right, but, I come close enough to it.
Jun 20, 2009 | Dometic Rooftop RV Air Conditioner
RV pilot light goes out
replace the thermocouple/flame sensor and make sure the flue/exhaust is clear and not getting wind gusts in it blowing out the flame.
Mar 01, 2009 | Dometic Rooftop RV Air Conditioner
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Refrigerators Logo
23 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
