Question about Kenwood KFC-W2525DVC Car Subwoofer
How can install woofer kenwood kfc w2525dvc
What type a box i need?
SOURCE: Kenwood audio equipment
there worth from 35 to 80$ per speaker ! plus the box. I've got the same ones 2x10 in a box and never had a problem. If I did it was always with the power amp settings. Remember the speaker specs when setting up the amp. otherwise sell them quick on ebay or your local cash converter shop.
Posted on Feb 24, 2008
  • 1114 Answers
SOURCE: I NEED USER MANUAL OR SPECS. TO BUILD PROPERLY SIZED CABINETS
Can't help you on the manual, but basic specs for both drivers are listed on crutchfield.com web site.
Easy way to do it is ; type in KFC-W2505 and the KFC-W2509 in your search engine and click on the Crutchfield web site. This will give the overall cubic dimensions of the cabinet, plus other info. Hope this helps...
Posted on Jul 01, 2009
budice7h20
  • 93 Answers
SOURCE: Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Posted on Jul 02, 2009
gotthebeats
  • 11 Answers
SOURCE: I have two 12" kenwood KFC-W3003 4 OHM 600
the cheapest way is to get a prefab box from sonicelectonix.com get it ported im hittin 130db with mine in a 2.3?cu ft center port(one big chamber). litterally my fiance cant drink anything cant smoke a cigarette, and all hell breaks loose when i have the window cranked and throw 400w rms at the pair so bout 200 ea. and that my friend makes my ears hurt very bad and they actually hit harder than my older style RE audio subs.
Posted on Oct 12, 2010
  • 37 Answers
SOURCE: I have a Kenwood KFC-XW1100DVC
If you're sure that you didn't drop the subwoofer while handling it outside of your Jeep, make sure your connections are solid. Perhaps you did not connect your wires from your terminal to the voice coils solidly. Otherwise, use your best judgement and determine whether or not the subwoofer is up to par on its normal performance. Try to keep the volume down for a little bit, to give it some rest.
Posted on Mar 01, 2011
Links dont open in my Outlook 2007, why?
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. In the Folder Options dialog box, click the File Types tab.
  4. In the Registered file types list, click (NONE) URL:HyperText Transfer Protocol, and then click Advanced.
  5. In the Edit File Type dialog box, click Edit.
    Important Make sure that you note the current values for the fields that are in this dialog box before you go to the next step. You may have to restore the values for the fields that you changed if this method does not resolve the issue.
  6. In the Action box, type open if it is not already there.
  7. In the Application used to perform action box, type "C:\Program Files\Internet Explorer\iexplore.exe" -nohome if it is not already there.
  8. Click to select the Use DDE check box if it is not already selected.
  9. In the DDE Message box, type "%1",,-1,0,,,, if it is not already there.
  10. In the Application box, type IExplore if it is not already there.
  11. Make sure that there is no value in the DDE Application Not Running box. If there is a value in this box, delete it.
  12. In the Topic box, type WWW_OpenURL if it is not already there.
  13. To close the Edit File Type dialog box, click OK two times.
  14. In the Registered file types list, locate and click (NONE) URL:HyperText Transfer Protocol with Privacy, and then click Advanced.
  15. Repeat steps 5 through 14 by using the (NONE) URL:HyperText Transfer Protocol with Privacy list item instead of the (NONE) URL:HyperText Transfer Protocol list item.
  16. To close the Folder Options dialog box, click OK.
  17. Test a hyperlink from Outlook Express.
hope this helpful
Jan 08, 2011 | Microsoft Office Professional 2007 Full...
I have wirerless internet and my xbox wont connect why
Here is xbox support:
http://support.xbox.com/en-us/pages/xbox-live/how-to/default.aspx
For Linksys routers:
Hooking up an Xbox with Linksys routers:
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Dec 02, 2010 | Computers & Internet
How do i set my NAT to open on my WRT54GS? what is the default password to access it?
Do this,
Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - 192.168.1.1 and press Enter...
Leave Username blank & in Password use admin in lower case...
1) On the first line in Application box type in ABC, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
4) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
5) Click on set-up and change the MTU Size to 1452 and click Save Settings...
6) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
7) Also assign the DNS Addresses on the Xbox
8) Turn off your modem, router, and Xbox...Wait for a minute...
9) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Nov 12, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot find email server att.yahoo.com ?
Under User Information, do the following:
In the Your Name box, type your full name the way that you want it to appear to other people.
In the E-mail Address box, type your e-mail user name, followed by @yahoo.com.
Under Server Information, do the following:
In the Incoming mail server (POP3) box, type pop.mail.yahoo.com.
In the Outgoing mail server (SMTP) box, type smtp.mail.yahoo.net.
Under Logon Information, do the following:
In the User Name box, type your user name. Do not include @yahoo.com.
In the Password box, type your password.
Select the Remember password check box.
Jun 21, 2010 | Computers & Internet
What type and size of box should i use with this
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
May 26, 2010 | Phoenix Digital PD-131 Car Subwoofer
I cannot send a pictuer to my own e-mail. Please help. Windows xp Frank
Open your email programme it could be outlook express, Pegasus, or outlook, (Here I am using outlook express). Click on file then new message, in the to box type the email address you are sending the email to. In the subject box type in whatever your email is about (like how to send a photo by email), click in the big white box below and type your message. Click on insert at the top of this new email message and then on picture, the picture dialogue box comes up, click on browse to find the folder you saved your photograph in. You might have to keep clicking on folder names in the big white box till you find the right folder name. in the to feild you need type your email add, then click on send
Mar 30, 2010 | Yahoo Mail
Need to change password for yahoo messenger and iphone
  1. Login your Yahoo! Mail account. (yahoo.com)
  2. Click your name (in this example, User) in the Hi, User greeting at the top-left of the page. From the menu that appears, select Account Info. A new browser screen appears asking you to verify your password.
  3. Type your password into the box and click Sign In. The Account Information page appears.
  4. From the Accountfavicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.ico Info menu, select Change Password.
  5. Type your Current Passwordfavicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.ico in the first box.
  6. Type your New Passwordfavicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.ico in the second box.
  7. Confirm your New Password byfavicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.ico typing it again in the third box.
  8. Click Save. Your passwordfavicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.ico has been changed.
Jan 21, 2010 | Yahoo Messenger
Internet light keeps blinking. sometimes all four
You may need to reset the router (your son's computer may have a virus or spyware, run the anti-virus program on it)
At the back of the Linksys Router you will find a reset button press and hold it for about 30 sec. (Make sure you are holding the button properly.),
it will reset all the settings of the router.
After that reboot the router, connect your computer with port no. 1, and then try to open 192.168.1.1 from the Internet explorer of your computer.
It will give you a message "The server at 192.168.1.1, WRT54GS require a USER NAME and Password.”
Now type "admin" in the password and it will take you to the LINKSYS ROUTER SETUP
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" sub tab...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Change NAT to open
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 05, 2009 | Linksys Wireless-N WRT150N Router
Where is the fuse box on x type
fuse box on the x type, one under the bonnet by the battary box and one in glovebox hope this helps
Mar 01, 2009 | 2004 Jaguar X-Type
Kenwood KFC-W2525DVC Car Subwoofer Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
