Question about Athearn Ho Rtr Kenworth Cement Mixer, Ross Island
How to remove and fit DRUM SHAFT BEARING FITS BELLE CEMENT MIXER MINI 140 150 (1989 ONWARDS)
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
A belle cement mixer,wont stay on when start button is pushed,changed switch ,still the same?
Sometimes the most simplest of fixes is verifying that you have voltage at your outlet and that you have voltage getting to the motor.
Check the motor's overload button; reset if necessary.
Take resistance readings:
  • start capacitor
  • run capacitor
  • and motor
If anyone of their specs are out of whack, that's the component that is defective and will need to be replaced.
Mar 24, 2015 | Masonry Tools
MY MINI MIX CEMENT MIXER IS BROKE DRUM WILL NOT TURN WHEN LOADED
This is the food mixer forum, not much cement gets mixed in the kitchen around here, too much danger of a flying rolling pin.
Sep 06, 2014 | Food Mixers
Concrete mixer motor pulley size
smallest available that fits the motor shaft ( around 11/2 ")
it is not the mixer speed you are worried about but the power required to drive a full mixer
Jan 25, 2018 | Dryers
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
I need to know how to remove the bearing from the drum. I have split the outer drum but can't get the shaft out of the back of the outer drum? My washing machine is a Hotpoint WT 960
this just takes a bit of mucle and time.
remove rear pulley and then refit screw (without washer) into shaft. screw the whole way in. then using a lump hammer knock shaft out. may take a good bit of hammerin.
knock bearing out then and also unclog the weep hole in bearing housing.
grease the bearing housing and press in new bearing and seal.
if old shaft damaged ( which prob is if hard to knock out) you will need to replace it.
screws holding shaft to drum usually impossible to undo so drill them out using a 8mm bullet bit.
fit new shaft, put some bearing grease on the bearing seal and re-assemble the drum
Oct 19, 2010 | Hotpoint Washing Machines
Iv'e got a belle cement mixer 150, i think the motor is on its way out, its around a 2007 model can you tell me if you can put new brushes in the motor if so how, or if i can have the motor reconditioned ?...
i have a belle 110v cement mixer just over a year old.Everytime i use it ,it switches itself off after mixing 2 barrows of concrete but it will run perfectly for hours when empty.(tryed this out on Monday)So therefore it only switches itself off when loaded.
Gets very hot quickly.
Any suggestions would be much appeciated.Brian
May 03, 2010 | Home Fencing
Hi, I love my Black&Decker bread maker, but recently it has black swirl stuff on the bottom of the bread. I found it was from the center mixer. The mixer is getting loose and it can be moved up and...
Hi Jenny,
The black swirl stuff is the lubrication from the bearing that used to be sealed on the bottom center of the bread pan. (The paddle fits onto this bearing shaft). That bearing is broken and is leaking, causing the whole bearing and shaft to move. Time for a new bread pan.
Hank
Oct 27, 2009 | Kitchen Appliances - Others
1984 Honda XR250 with wrong clutch, I think.
The kick shaft gear, idler gear, and clutch drum gear on the 1985 xr250 and below are smaller tooth gears than 1986 and newer. I have an 85 and an 88. I had to replace the 85 kick gears 3 times. The last time I replaced them I found that the larger gears on the 88 fit as long as you replace only the gears. The kick gear comes off the shaft and the larger tooth gear fits on the shaft. The larger idler gear fits where the smaller tooth idler was and the drum gear comes out and the larger tooth gear will fit there. Or the drum you have with the larger gear will now fit the other gears. This is a better solution than finding another drum with the smaller tooth gear because the smaller tooth gears will not last. I hope this helps.
Jun 09, 2009 | 1985 Honda XR 250 R
Athearn Ho Rtr Kenworth Cement Mixer, Ross Island Logo
27 people viewed this question
Top Athearn Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Athearn Toy Expert? Answer questions, earn points and help others
