Question about Canon PIXMA MG8220 Wireless Photo All-in-One Inkjet Printer
Loud screeching noise from canon pixma mg 8220
Loud squeaking at start up turn off or when printing
SOURCE: Pixma 5000 Canon
have replace all cartaages put the blue wont print
Posted on Oct 06, 2008
websnail
  • 419 Answers
SOURCE: A loud banging noise from inside - as it adjusts post printing
I'd check that there's nothing that's fallen into the rear paper feed that is now causing the rollers to jam and release with the bang you mention.
If you're feeling brave I'd try holding the printer upside down (get a friend to help you and watch out for the scanner sliding out!) and give it a bit of a shake to see if anything drops out.
Posted on Jan 23, 2009
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
SOURCE: my canon pixma mp530 makes a loud noise most times
My MP-530 would try to boot up making a noise like something slipping or grinding, ending with ERROR Code 5100.
Solution: Open the Lid. The drive belt was loose and not able to drive the carriage. There is a gear on the right side of the carriage and a pulley on the left side of the carriage. The spring which holds the pulley tight is missing or broken. I was not able to see the tension spring. To put tension on the pulley, to tighten the drive belt, I cut a Popsicle stick into a wedge and inserted it into the middle slot right of the pulley.
Close the lid and power back on. Runs like new. Hope this helps.
Posted on Aug 03, 2009
Douw
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
My Canon Pixma MG5200 will not print E-MAILS or browser items
When you rightclick on the side you want to print, choose print and some times you have to chose printer.
Aug 10, 2014 | Canon Large Black Pixma Mg 5200 Compatible...
Very loud screeching noise has tub turn modelfdez16rbso serial3 XDH3299197
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 09, 2011 | Frigidaire Dryers
Dryer when turned on makes a loud screeching sound
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 29, 2011 | Dryers
My dryer is making a loud screeching noise when I turn it on, it is only 3 years old.
heatman101
Asker
Dec 29, 2010 | Whirlpool WED9200SQ Electric Dryer
Squeaking/grinding noise when turning the wheel
Are the front brake pads ok? Some have squeal indicators, it is a tin plate that touches the disc (without damaging) to warn you that the brakes are worn. On the initial stages it will happen more so on slow cornering but will quickly get louder over a matter of days.
Check the pads for thickness, should be min 6mm
Jan 09, 2010 | 2001 Dodge Stratus
I am getting an E6 flashing on my printer
First try a hard reset, as follows and see if it clears:
Turn off the canon printer
Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
Hold the Power Button, release the Resume Button.
Not releasing the Power Button, double click “Resume” and release Both Buttons.
Click “Resume” for Four times
Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
If the error still exists then;
Solutions for error codes
Issue: ERROR LED: E, 1, 6
1. Press Black or Color button to clear the error and continue printing
2. Replace ink cartridge(s) MP150 / MP170
Here is the support link should you need it:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12764
Good Luck
Dec 31, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My dryer works right it's just when it's running
Usually lound screeching and squeaking noises are caused by dry drum rollers. You need to lube the rollers or replace them. When I say lube the roller I mean the shaft and bearing part of the roller.
Sep 24, 2009 | Hotpoint Dryers
Dryer turns and heats, but makes a very loud squeaking (or should I say, SCREECHING) noise. The heavier the load, the louder the squeaking.
Does it sound like a belt ?
Or does it sound like metal ?
Might need to replace the drive belt..
Or - it could be the bearings..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Loud squeaking under the hood
does it do that noise when is running or when u start it?
Jun 14, 2009 | 1998 Dodge Neon
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Canon PIXMA MG8220 Wireless Photo All-in-One Inkjet Printer Logo
98 people viewed this question
old marine
old marine
