Question about Vacuums
Replace power nozzle brush on Model N109J
Need to remove brush in power head
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
reddevil6
  • 1673 Answers
SOURCE: Lux 7000 Power Nozzle bulb replacement
There should be some screws that you remove from the bottom. Then pry up from the back and the top should come off.
Posted on May 13, 2008
  • 44 Answers
SOURCE: electrolux 6500sr power nozzle motor
If you go to aerusonline.com, there is a dealer locater function that will allow you to find the nearest aerus electrolux store. If there isn't one local, I would call one of them and have them ship it to you. You may be able to find an aftermarket motor on line, but there are several different models so you may or may not get the right motor. Good Luck!!
Posted on Jan 03, 2009
  • 134 Answers
SOURCE: Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
  • 694 Answers
SOURCE: my electrolux epic 6500 power
No. If the power nozzle motor is running, then a new belt will do the trick.
Posted on Sep 26, 2010
Why won't power nozzle attachment turn on?
you may not have power coming from the vacuum. those plugs are known to fail.
Sep 02, 2015 | Electrolux Vacuums
How can I repair? The power nozzle N109J is not operating, but the handle can turn the vacuum on/off and there is plenty of suction. Is it possible the electric connection in the handle is broken?
Yes,also try checking the connection from the hose to vacuum.Make sure hose is in vacuum port properly.To test this just wiggle the hose end up and down with machine running.It the problem is there the head should start intermittently.If not get back to me with more info.hope this helps,it is a fraustrating but fixable problem. Chris
Aug 16, 2014 | Electrolux Vacuums
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
My electrolux Epic 6500 power nozzle Model N109J will not work. It had an intermittent short which I thought I fixed (some of the insulation on the wires were pinched). I fixed the wires and it worked...
The switch is definitely a possibility, but other problems can also cause this.
Bad switch, needs replaced.
Broken wiring in power nozzle, wands, hose, or canister.
Bad PN motor.
I strongly recommend taking it to the nearest authorized Aerus Electrolux store for a diagnosis (should be free). Allowing them to do any repairs necessary is recommended, as well. This will ensure it's done correctly.
http://www.aerushome.com/storelocator/
Feb 23, 2011 | Electrolux Epic 6500 Vacuum
How do you replace the belt in an Electrolux model 1521
I guess you are talking about the belt in the Power Nozzle, right?
(for the vacuum cleaner itself, has not belts in it...)
So-- if we are talking about the power nozzle:
Lay the floor part of this nozzle on a bench or table (with newspapers underneath!!)
Usually there are 2 or 4 large head screws on that smooth metal floor plate--
Remove them, and this cover plate usually pivots forward, exposing the brush, the drive motor and the belt-
Notice the height adjusting settings, for how far the brush goes into the carpet-- and determine if you want to use that same setting,-- or if the brush is worn, you may want to adjust the brush 'out' more, so that the bristles get into the carpet more?
Can you remove the brush?-- removing the end farthest from the belt, first?
This allows the old belt to come off, Now slip the new one on-- notice the notches-- make sure the spacing of the notches in the belt matches the notches in the pulleys.--
Now can you insert the brush back in the bearing slots-- Belt end first?-- Dercide whether to use the same depth, or a deeper brush depth, and nestle everything back in to the retainers. Does the brush turn easily? -- a few drops of oil on the bearings won't hurt.. Be sure to clean all the strings and threads and hair that gets wound around the brush, while you have it all in the open.
You can test the installation when you are safely away from the moving parts-- does it turn freely now?
Replace the cover plate, and tighten the screws-- remembering that they just need to be snug.
Let us know how this turns out-- and if we can help more.
Mack B
Jan 27, 2011 | Electrolux C101 Bagged Canister Vacuum
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small...
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Dec 31, 2010 | Broan-NuTone Vacuums
How do I change the belt on my Sears vacuum?
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 15, 2010 | Kenmore 25512/ 25513 Progressive Canister...
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Chris J.
GoVacuum
Apr 07, 2010 | Vacuums
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
Chris J.
GoVacuum
Apr 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
