Question about Element Televison & Video
Hooked up dvd player. Don't know what to do to view it on tv
I have hooked it up to my cable box and programmed the remote for the cable box. Can turn dvd player on and off but can't get it on the tv
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
Use DVD Avi jack and cable to connect with flat panel. Select AVI input mode in flat panel option menu.
Posted on Jul 09, 2015
SOURCE: Westinghouse LVM-37w1
I have had this problem since about superbowl time. If I powered the set off, waited 15-20 seconds, and then powered on, it would work again for a while. Repeating this drill a number of times would lead to stable operation. We resorted to a course of turning on some XM music from DirecTV when we weren't watching. I tried a technician knowledgeable on this set, and it would have cost $500-800 to repair the set. We learned from different forums that the likely culprit was either the power supply board or the LCD controller. We also picked up the rumor that Westinghouse had quit making replacement part. It would seem that the management of this organization has a death wish. TO THE CHASE: shopjimmy.com is now selling parts from canibalized sets. They have a non-DOA warranty and a good return policy. A power supply from "Jimmy" solved my problem. I have one important hint: To remove the back, take out the obvious screws and the base. Then remove the ~5/8" rods that protrude from the bottom. There is a screw up inside each rod.
Posted on Oct 22, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
SOURCE: no signal when hooked up with a digital cable box
I had the same problem and had the cable guy out and everything thinking it was my box. I figured it out by myself here is what i did to fix it. I have the vizio 32 inch hooked to an hdmi cable and through the cable box i had the aspect ratio on 1080i and i should have had it on 720p once I switched it I havent had the problem since.
Posted on Dec 21, 2008
skotkolr
  • 558 Answers
SOURCE: Cant program remote control..atlas 1056B01
You can try Funai and Emerson codes
Posted on Apr 06, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Memorex MVD2016 DVD Player
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
I have BOSE speakers plugged into a small lcd tv. when the tv is off, I'm still hearing cable audio. why? i'll clarify. my tv has rca jacks connecting it to a couple of small bose speakers. sounds...
Your TV output is a pass-thru from the coax cable then. The only solution- turn the volume down, or unplug them.. Or get a cable box. A VCR may work as a temporary cable box, and if you have a remote for it, you should be able to just turn off the audio at any time with a VCR remote. (unless the VCR also has a pass-thru only audio output)
May 25, 2009 | Audiovox DVD Player FPE1505DV
Can't get to recorded programs
Check and make sure you have the DVD Recorder hooked up to the TV. I think you have the Cable box or Satellite hooked up or else you could not record. So there is a second set of outputs on the back of your DVD Recorder, Buy a set of RCA jacks and plug them into the Yellow,White, Red Plugs of your DVD Recorder, Then plug the other end into your TV in either L1 or L2 inputs, whichever ones are free.
May 12, 2009 | Panasonic DMR-E85H DVD Recorder
DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Jan 14, 2009 | Olevia LT32HVM 32 in. LCD Television
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Konka KLC 1508U TV
I am using a Phillips Universal remote I got at Target that controls 3 devices. The code for this is 0504. I have it hooked up with a cable box and in order for it to work correctly, I have to turn the TV on before I turn on the cable. If I don't, then channels don't change, etc.
Sep 03, 2007 | Televison & Video
Televison & Video Logo
171 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
