Question about Konica Minolta Office Equipment & Supplies
C353 firware trying to find current fiware version on printer controller
  • Konica Minolta Master
  • 6,696 Answers
Only available at a secure Konica Minolta web site copier/printer companies keep the copier/printer operating systems secure avail able only to dealerships and KMBS
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 18, 2016
My konica minolta c353 the screen is not displaying
See if you can get a new control panel.
Jan 26, 2016 | Konica Minolta Konica Bizhub C353 Drum...
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
Mar 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
How to reset a Bizhub C353?
What are trying to reset. DONT MESS with stuff in Tech rep mode can cause serious problems. What are trying to reset!!!!!!!! CODE???
May 27, 2014 | Konica Minolta bizhub Office Equipment &...
C-5102 error in C353
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Feb 08, 2014 | Konica Minolta Bizhub C353 Copier
We keep receiving a T.30 Protocol Trace Report with the "Type: Receive" and "Result: Communication Error (17)". How do we figure out what this means? Thnaks.
If this is printing out and consuming a lot of paper it can get annoying. This report is intended for a technician to trace problems with your machine. The report basically tells you that your fax attempt failed and gives all the technical settings. To the average user this is meaningless. The print feature for this is normally turned off, but I have seen a few cases where the default was set to print. Under the diagnostics menu, find the T-30 error setting and set it to never. Check the firware on your printer to make sure it is current. Print the configuration page and check the firmware version on the front page. The current version is 48.181.8. There are many modem fixes included with the firmware.
May 23, 2011 | HP® LaserJet M5035 MFP Laser...
Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Nov 12, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I need the driver for the Konica Minolta C353 Series PCL printer.
go to konicaminoltaus.com they have the drivers for all current models
Oct 22, 2008 | Konica Minolta Office Equipment & Supplies
Connection server failed 8001000D
downgrad your psp using pandoRa.
but becarful to your current firware and chose a suitable version of pandora and desperato del cementiro
May 31, 2008 | Sony PlayStation Portable (PSP) Console
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
