Question about Germ Guardian Humidifiers
There is no spray coming out - Germ Guardian Humidifiers
Clean the fan blades
Don't use a hose, it will rust the motor and bearings.
if the blades are metal, and the unit is detached from the furnace. Try carburator cleaner or brake cleaner - out doors away from flames. Also, rotate so no solvents get to the bearings and wash away he lubricants. The solvent evaporates quickly but it will take a minute so don't be too impatient to get to the next blade.
If they are just dusty, and you don't want to dismount the unit, try some canned air - office stores carry this for cleaning keyboards and such. To get a really good stream, turn the can upside down and spray. The liquid propellant will come out and makes a really good cleaner. It will be cold cold cold as it evaporates and some ice will form if the humidity is high enough.
Effectiveness will depend on what is causing the dust to stick to the blades - oil film, soot from wood/coil/fuel oil and cigarette smoke are difficult.
Mar 10, 2014 | Essick Air MA1201 Moist Air Whole House...
The fan is loud and the motor is running "hot". Is there a place to oil the fan's motor?
This is a sealed bearing motor so there is no oil ports. You can blow out with compressed air and spray motor shaft with WD-40. Be careful not to spray any lube inside motor. If you can get to them blow out motor cooling ports .this should help motor run cooler and quieter. Hope this helps you. Thanks
Jan 02, 2011 | Essick Air Credenza 696 400 5.2 Gallon...
Why do i have to go outside and manually hit the reset button on my heat pump to get the fan to come on?
that switch is a pressure switch that trips when the freon pressure get to high usally the problem is the coils on the unit are clogged water alone is usally not enough home depot sells a spray can of coil cleaner back were u would find the air filters depending your store follow directions CARFULLY and this sould sovle the problem.
Mar 15, 2010 | Humidifiers
No manual for Bonaire humidifier BCM 4510-U
If someone put it togetherm you can take it apart.
See if the dicharge grill slides up and the bottom vcan be pulled out like a window screen. If so, ,other panels may also do so in order to access the internals, Unplug unit when in the water or around fan. Do not run unit without panels in place. Any fan cleaning use something like 409 spray and rinse off with a spray bottle also. Keep water out of all and any electrical. Rinse and leave no cleaner in humidifier to be mixed with misting. Good Luck
May 17, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
Mar 07, 2009 | Holmes Products Cool Mist HM3500...
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Hunter model 33201 stinks due to mineral build up, but I can't get the fan part disassembled to clean it. There are no more screws to take out, and I don't want to break it... help
Soak what you can in white vinegar. For the rest put some of the vinegar in a spray bottle and carefuly spray and use an old toothbrush.
Good luck
HVAC Teacher
Feb 17, 2009 | Hunter 33201 Humidifier
HUMIDIFIER IS VERY NOISY AND MIST SPRAYS FROM ONE SIDE ONLY
You should have bought a Cleanaer! It's totally silent, reaches all corners of the room with its patented LiquidIon technology not only takes the bad particles from the air, but locks them out for good so they do not reenter the airspace when you cross the room or disturb the furnishings.
Feb 15, 2009 | Bionaire Humidifiers
Humidifiers Logo
108 people viewed this question
Top Germ Guardian Humidifiers Experts
Paul Carew
Dennis
Are you a Germ Guardian Humidifier Expert? Answer questions, earn points and help others
