Question about Alpine MRP-M500 Car Audio Amplifier
How to wire door speakers to this amp
Best way to wire up door speakers
My speakers do not work but my subs do.
Good day sir, hi, there reason why speakers don't work could either be the folowing:
  1. you speaker voice coil is burnt, to test, you need to get the door speakers out and locate the terminals, prepare a 1.5 double AA battery, use this to test you speaker. connect a wire from the negative of the battery to the negative of the speaker, and the positive battery to the positive terminal of the speaker with a series of gentle taps, you should hear clicking sound. if not replace the speaker.
a9b085b.gif Do it on the other door speaker.
2. check your speaker line from the amplifier to the door speaker.
3. check your power amplifier for loose and improper connection.
4. check your power amplifier itself. Thats it.
Its a little work, visit your local electronic repair shop if your speaker still won't work.
Oct 08, 2009 | Car Audio & Video
I have a chrysler lhs 2001, and my car has 6.5inch speakers in the front doors. for some reason i cannot get them to play sound. the speakers are fine and the wire's are still pushing power, but i dont...
Yes, you might have an amp in your way. The speaker wires could be going to an amp under the dash. the best way is to run you own wires to the speakers this way you will be sure of the connection.
Sep 12, 2009 | Car Audio & Video
We need the colors of the speaker wires
I can email you the diagram...would be easier for you to see...but here it is in writing (we can't post pdf. files).
Right Rear Speaker-- yel/red & grey/red
Left Door Speaker -- wht/blu & blk/blu
Left tweeter -- org/blu & Brn/Blu
Left Rear Speaker -- yel/blu & grey blu
Right Door Speaker -- wht/red & blk/red
Right Tweeter -- org/red & brn/red
Jun 29, 2009 | 2003 Mitsubishi Eclipse Spyder
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
Radio wiring
The factory wiring connector hook-up for the Mustang is:
Radio / Power Connector:
Red - Ground
Speaker Connector:
Your best bet is to buy a radio install kit and adapt it to the Mustang connector. Hope this information helps.
Oct 19, 2008 | 2002 Ford F250 Super Duty SuperCab
Installation of Parrot hands free car kit - bluetooth
In the parrot kits I've seen, they insert a relay to switch the audio to the phone. This only works with 2 speakers generally. Your vehicle either has dedicated amp channels for each of the 3 speakers/door or the installer tapped into the wrong point. If it has individual amps for each speaker, they may need to force the amp to shut off to get it to mute the audio.
May 13, 2008 | Car Audio & Video
Constast cycling sound from my stereo onlt its intermitent
If the other speakers play after the door speaker wires are disconnected, the problem is likely a speaker wire shorted to the door. If the vehicle had OEM amps and you didn't bypass them, that could also be a problem.
Disconnect the door speaker wires from the amp and check for continuity from the speaker wires to ground. There should be none. Also check the resistance across the speaker wires. They should read approximately the same as the rated impedance of the speakers.
Mar 02, 2008 | Soundstream PCA1000D Car Audio Amplifier
Alpine MRP-M500 Car Audio Amplifier Logo
21 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
