Question about Apple Computers & Internet
Pink spots ipad screen - Apple Computers & Internet
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: RU -44, small "pink" spot on screen.
Green is missing from the area where you see the pink (actually magenta) spot. This might be due to a large amount of dirt on the green lens. It may be due to damage to the face of the green picture tube. You need to remove the front screen so you can look into the lens and determine that.
Depending on the make and model of TV, the screen may be held on by snap fasteners and come loose when you pull on the plastic bezel surrounding it. Or the bezel may pull off to reveal brackets screwed into the cabinet that secure the screen. Or there may be a trim strip under the screen that pulls off to reveal screws. Remove those and the screen will swing up and off.
Once you can see the lenses, clean them with a soft rag and glass cleaner. With the set on, look down into the lens and you can see the face of the picture tube. If you see a dark spot on the face, the tube is damaged and would need to be replaced
Posted on Apr 22, 2009
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
I have pink spots on my tv screen. do you know
you most likely have a light engine problem ocouring causing the pink spots
they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
Oct 30, 2009 | Panasonic PT-44LCX65 Television
Sony Wega - Pink Spots On Screen
You have a defective optical block. Contact Sony support and have your model and serial numbers handy. Sometimes they will warratny these even after the 1yr warranty has expired.
May 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Apr 22, 2009 | LG RU-44SZ61 44" Rear Projection...
Pink spots on screen sony wega 42" reaprojection tv
This TV has a known problem with the optical Block. Please call Sony Customer Relation and ***** them until they send someone to replace the optical block
Jan 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Pink and Blue Spots
Contact sony as they have been helping customers with the blue spot issue on alot of the wega as the optical block fails causing the blue spots.Sony will cover the cost of the repair. Heres the link to Sony explaining what they will do.
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Nov 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Pink and Blue Spots
Sony guarantee the consumer to replace the optical block assembly for thousands of dollars in parts and labor every four years or when the pink and blue spots appear every time. Then replace the optical block assembly again and again every time the spots appear.
Aug 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony 42" grand wega LCD
We Cleaned the optic block as was instructed by another post. But now we have a wide ribbon of light yellowish to the right of our screen. Could it be more dust to be removed or now we can see there is more problems then we thought? Over all the screen looks much better. But a far cry from when it was new.
Apr 21, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Computers & Internet Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
