Question about NorStar M7208 Corded Phone
Line 5 does not ring
The first 4 lines of our system ring but the 5th does not. How can we get it to ring
cnavarro
  • 2460 Answers
SOURCE: Lines 4 and 5 in use.
One of the annoying features of a Norstar is the auto hold. If you switch from line to line, you put the calls on auto hold. It doesn't take much to conference two lines together and drop out of the call. Now you're at the mercy of the Central Office as to whether it sends a disconnect to drop the lines.
Two bad things that we advise customers to unplug the system is when they have mystery lines tied together and/or external paging tied up. That drops all current connections and lets you start again.
Carl
Posted on Sep 08, 2008
ynotphone
  • 192 Answers
SOURCE: M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Posted on Mar 20, 2009
  • 60 Answers
SOURCE: Line 5 doesn't ring on one phone
That is done thru config programming, you need to add line 5, appearance and ring to station. This will automatically put the line on your next line button.
f** config
Posted on Aug 06, 2009
consultel1
  • 860 Answers
SOURCE: only certain lines ring on certain phones
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring2.gif
press next key (lower right arrow)til you see the line port number you wish to program (004)
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
press the release key when finished
Posted on Oct 07, 2009
Testimonial: "thank you so much!! thats exactly it!!"
consultel1
  • 860 Answers
SOURCE: My Meridian M7310 phone system is unable to
Either the line from the telephone company is out or the line port in the line card is defective. The easiest way to determine if its one or the other is to report the line trouble to the telephone company. they'll check the line up to where it comes into the building, and if theres a problem on thier side they'll get it back in service. If the report the line is good to the building, then you'll need to call your telephone system service technician.
Posted on Jul 28, 2010
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
Line 1 of the pro star 816 will only ring on one of our phones and not the other. Line 2 and 3 rings on the seperate phone but not the other one. How can I make all lines ring on both phones?
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
Jan 08, 2010 | Samsung Prostar 816 Phone
Our phone has 4 lines and about 5 phones but if you are on a phone call if another line line rings in the phone does actually ring so if you are not looking at the phone directly to see if any lines are...
You can do 2 things, set up call waiting by dialing ^7321 for outside calls and *7311 for intercom calls, and make sure the phone is programmed to ring as a member of an ICD group. Making the 5th digit 0 will cancel the feature.
Carl
Dec 02, 2009 | Panasonic KX-T7630 Corded Phone
Secondary phones will not ring
with the handset2.gif down enter #20 the screen should say MMC DISABLED
2) enter in #62 the screen should say day ring2.gif assn
press #when finished. hope that helps
Sep 22, 2009 | Samsung Prostar 816 Phone
Stations don't ring even though day ring and night ring enabled.
Sounds like the ring assignmet programming has defaulted.( all lines ring at station 4 only)
repeat for each line
Jul 20, 2009 | Samsung Prostar 816 Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
No issue, just a question. Looking at RCA 25425RE1 4 line business phone system. If all four lines are busy , will the caller of the 5th call get a busy signal or does the phone have "busy no answer...
ANY phone system will have this problem.
If 5 people call in, the first 4 will be answered, but the 5th will get busy, as there are no lines available into your phones voicemail system.
IF, you have voicemail through the phone company, you can get their voicemail feature for extra.
THEN, if 5 people call in, the first 4 go to the phones, and the fifth gets the voicemail greeting.
It would be dependant on the line provider how many calls their voicemail would handle at one time. SO if 500 people call in, 4 get through, and MAYBE 5 go to voicemail, the rest get busy.....
Jan 13, 2009 | Lands Phones
Group forwarding after a delay
In memory block 4-1 for the extension's port, The Lkey for the CO line is lit green for immediate ringing, red for delayed ringing, and off for no ringing.
In memory block 1-1-77 you enter the CO's delayed ringing timer in seconds.
I wouldn't try and deal with seperating into tenants.
What I would suggest is in 4-19 restrict outbound trunk access (corresponding Lkey for CO line is lit to restrict)
For example:
Stations 1-4 would not be allowed to dial out on CO lines 5-6
Stations 5-6 would not be allowed to dial out on CO lines 1-4
This way Company A is not tying up Company B's CO lines for outbound calls and vice-versa.
Apr 09, 2008 | NEC Electra Professional ETW-16DC-2
NorStar M7208 Corded Phone Logo
15 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
