Question about Dryers
No heat and drum not turning indesit IS70CS
DRYER NOT TURNING AND NO HEAT COMING THROUGH, though we can hear the motor
SOURCE: drum in dryer not turning but still heat
Sounds like you need a new dryer belt, call sears for new belt. Install the new belt around the drum and to the motor located near the bottom of the machine.
Posted on Oct 20, 2006
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
  • 11 Answers
SOURCE: indesit dryer IS70CS
sounds like the heating element or thermostat has gone in the dryer these parts can be bought from www.indesitservice.co.uk or www.espares.co.uk
Posted on Jan 24, 2009
  • 12 Answers
SOURCE: Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Posted on Sep 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: heating but drum does not turn
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
Posted on Dec 27, 2009
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
BURNER NOT COMING ON .DRUM IS TURNING .GAS IS ON .LOOKS LIKE NOT IGNITER HOW DO I CHANGE IGNITER?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 15, 2011 | Dryers
No heat coming from drum when spinning with our indesit idc75 drier can u help? looked for reset butten but cant find one can u please help
heatman101
Mar 15, 2011 | Dryers
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 05, 2011 | Indesit Dryers
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Indesit Dryers
Pushed dial, dryer would not start. Heating coil on, can feel the heat and hear ticking.
If the heating elemnts are coming on but the drum is not spining then the motor could be bad or the belt could be broken that turns the drum. The motor could also be on a thermal overload in this case unplug the dryer or turn off the circuit breaker for 15 minutes and let everything cool down. After turn the breaker back on or plug it back in and give it a try if you hear the motor running but the drum is not spinning then the belt is probably broken and will have to be replaced.
Jan 12, 2010 | Whirlpool LER4634J Electric Dryer
Will not heat. I can hear the motor/blower running, but don't hear the gas turning on.
heatman101
Jan 04, 2010 | Kenmore 63942 Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Indesit washer dryer, washer is fine, but dryer does not heat up
If you don't hear the fan running then the fan motor has gone bad. If the fan motor is bad then most likely your element has burned out. If you hear the fan motor than probably your element has gone bad..
Jul 29, 2009 | Splendide 2100 Vented Washer-Dryer
Indesit dryer IS70CS
Aug 02, 2008 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
11 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
