Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Error 02 803 HOW TO REMOVE TAPE
TAPE WAS DAMAGED AND NOW STUCK IN MACHINE I HAVE REMOVED TAPE FROM PATH AND NO TALE IS OUTSIDE OF CASSETTE
2 Suggested Answers
SOURCE: I have a Sony UVW
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Posted on Nov 13, 2008
How do I get a VHS tape out of a Go Video DVD/DCR combo?
you will have to open it up to get it out as the tape might be stuck around the play heads
Oct 23, 2017 | Televison & Video
Broken tape. Cassette will not eject. How can I correct?
With power off, you will have to disassemble the player to get access to the tape mechanism. You will find tape is preventing the cassette door from closing to allow ejection. Remove damaged tape. Apply power and press EJECT. Turn power off and inspect the mechanism to be sure all tape debris has been removed, then reassemble the player.
Apr 12, 2016 | Sanyo DVW-6100 DVD Player/VCR
I experience problems with my VCR. A tape got stuck. After I removed the tape, it comes up with an error message F03
If you have children who can access the machine, unplug it, turn it upside down and listen for any rattles or loose bits inside. Kids are notorious for 'posting' coins, half eaten snacks and the like into the 'letter box'. Any loose objects, particularly metal, MUST be removed before switching on again. If a tape has become damaged, bits left inside the machine, it will have to opened up to remove the debris and ensure that the tape transport path including all rollers etc are cleared.
Jul 04, 2014 | Panasonic Televison & Video
Tape is stuck inside a technic RS-TR575
This is the biggest reason why I say that the designer of these fancy little door/cradles SHOUL HAVE BEEN SHOT before invention. With a strong longnose plier break the casing of the cassette The Technics that I worked on the lid of this door can be removed from the outside Be careful with the tape itself if the recording is of great value to you that you do not stretch or break the tape. REMOVE all power batteries or mains or both ! then turn the flywheel in the OPPOSITE direction so that the tape can be unwound. You do get empty shells that can be used in the place of the one you gotta break the shell It remains a messy sort of business After you have removed the tape inspect the rolle and capstan shaft are they CLEAN and free running to prevent this from happening again. In the future it is a good habit to fast forward or rewind the tape from end to end.In the user instruction booklet some manufacturers recommend this. If you are scared to damage your machine then get this done by an expert and ask him/her to show you in future.
Jan 21, 2012 | Technics RS-TR575 Single Dual Cassette...
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Apr 19, 2008 | Philips VR620CAT VCR
Camera cassette errors
Often in this situation there are two issues that can casue the problem you are having. 1. The tape is casuing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. Otherwise it may need to be serviced by your local technician. Let me know how it goes.
Jun 27, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Stuck tape
If you haven't already done so, don't get overly forceful to avoid bending or breaking something. Often the cassette carriage mechanism is gear driven, and by moving the gear one direction or the other will unload the tape. You may need to disassemble the machine further to gain access to the drive mechanisim. Sometimes the carriage mech. can be entirely removed from the VCR by removing the attachment screws. Other times, these screws are made inaccessible by the tape itself. Look down on the right side of the carriage. If you do remove the carriage, mark the gear positioning first! as the gears must be positioned back exactly as they were from the manufacturer. You might need to employ the services of a technician if things are complicated.
May 26, 2007 | Panasonic AG-DV2000 Mini DV VCR
Electronics - Others Logo
137 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
