Question about Landscape Lighting World VOLT "Infiniti TM 35" Outdoor LED Spotlight
Volt "Infiniti" 35 landscape lighting will not turn on.
All other lighting works. The unit is less than 1 year old.
Will not charge when plugged in to electricity
1) Order a new charger. 24 volt 3-amp.
2) Replace the batteries if they are over a year old. Usually two each size U1 gel\AGM or SLA 12volt 34amp-hour.
Nov 01, 2013 | Ctm HS-2800 Power Wheelchair
Everything seems to be working but we are not getting any water in the bucket. The unit is less that 5 years old?? Where should all of the settings be set for??
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem. Please let me know. Thanks.
Jul 12, 2011 | Danby DDR586R Dehumidifier
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
the unit without the filter. Filter should be cleaned once every 2 weeks.
level
in basement applications. Raising the unit up off the floor,
problem.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
How do i replace the camshaft position sensor on a 2004 infiniti i35
hi, i have infinity fx 35 2003 it light on the service engine camshaft position sensor bank 1 , i replaced the bank 1 after 3 hour it light on again service engine + VDC off and slip i put the scanner it told me camshaft position sensor bank 1 again what can i do ?
Jul 24, 2010 | 2004 Infiniti I35
2005 Infiniti fx 35
a good 12 volt with trikle charge,it take a bit longer
to recharge but a more better way to recharge it
Apr 12, 2009 | 2004 Infiniti FX35
Dead battery replace, died again 3 days later
12 volt is actually a misnomer of sorts... it's actually closer to 13.8 volts i believe. if the voltage regulator is not working right you could very well be frying the battery. replacing it is the cost of the alternator + labour (unless you do it yourself).
Robert
Dec 16, 2008 | 1997 Infiniti.5 J30
Infiniti j30 interchangable parts
It depends on what parts you're thinking of. Some will carry over between years, and some may not. Minor restyling on the exterior and lighting may present some difficulty, and the 96 is an OBD2-emissions controlled engine, so its ECU, engine bay harness, and many sensors may not work on the earlier car (which is the much less-stringent OBD1 emissions control).
Sep 15, 2008 | Infiniti J30 Cars & Trucks
35 Year ols Camera doesn't work right?...
is it b&w film? You said you were developing it yourself. if so, it could be a darkroom issue where you may not be keeping it light tight.
Jan 12, 2008 | Konica Camera 35mm 27 Exposures Outdoor -...
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Landscape Lighting World VOLT "Infiniti TM 35" Outdoor LED Spotlight Logo
Top Landscape Lighting World Home Security Experts
Lawrence Oravetz
Are you a Landscape Lighting World Home Security Expert? Answer questions, earn points and help others
