Question about Maytag LAT3600A Top Load Washer
Maytag washer @Shawniem, what about the new water valve, should I change the back the original water valve?
IFIXALL
  • 868 Answers
SOURCE: maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Posted on May 14, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Part Change?
I haven’t had to change the water inlet valve but is this the valve assembly you purchased?
http://www.repairclinic.com/SSPartDetail.aspx?s=t-fav6800aww-%3d%3dc292i1032809&PartID=1032809
It looks like they throw in an install instruction sheet at this parts supplier site. If you have this do they speak to adapting the wiring harness to the H/C valve assembly. I’m sure you are not lucky enough to have male spade connections on you replacement inlet valve. If they are spade lugs this would be a piece of cake to interface too. Looks like a molded connector on the inlet valve to terminate the 120VAC power to the valve assembly.
I called the supplier above and if your machine starts with serial number 18 or above you need to purchase an upper LED wiring harness p/n 1185286 $55 to interface to the replacement H/C valve you purchased. Or you can purchase p/n 1404313 wiring info for $7.50 for the DIY’er. I know this is a bit frustrating. I don’t have the valve in hand so I can’t offer a quick solution. I’m willing to bet the wiring harness they are selling for $55 is nothing more than a cable with proper female/male mating connector transitions to interface to the factory 120VAC connections to the inlet valve. If my water inlet valve fails I would be in the same boat as you but I would make up an interface cable before spending $55. Maybe a more knowledgeable forum member can offer a better solution. Good luck to you.
Posted on Feb 19, 2009
sclarke7
  • 222 Answers
SOURCE: maytag neptune washer hot water fill problem
replace the valve
Posted on Sep 04, 2009
buffalonyman
  • 1865 Answers
SOURCE: We have a Maytag Atlantis washer. The cold water
The solenoid valve is failing, (common failure part) replacements are about $20. Replace the water solenoid valve
Posted on Nov 12, 2009
mastatech
  • 478 Answers
SOURCE: Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Posted on Jan 10, 2010
No cold water
Water Valve
Maytag Original Top Load Washer
If the problem with your Maytag washer is that is not filling properly, not taking cold water, not taking hot water, or not taking any water at all.
Or if the washer keeps taking water and overflows even when the washer is on the off position.
The problem could be a bad water valve. To check it out, do the following.
1. Disconnect the washer from the wall outlet
2. Open the controls panel
3. Remove the cabinet
4. Set your multimeter to read more than 2000 ohms
5. Take a reading between the two terminals on the two solenoids on the water valve
6. The reading should be between 700 and 1800 ohms on each solenoid
If the reading is infinity on any solenoid, the water valve is bad and most be replaced
Nov 18, 2013 | Maytag MAV7600 Top Load Washer
I am having difficulties replacing the water valve on my maytag top load washer, model mav208daww. How do I get to it?
Hi.
Disconnect power cord or trip circuit breaker. Unplug the water hoses after turning off the water supply. Using a screwdriver, release and lift up the washer top panel. Using needle nose pliers, disconnect the wires from the old valve, and undo the hose that feeds water into the tub. From the back of the washer, I undo the screw holding the valve in place. Remove the old valve. Connect electrical wires and hose to the new inlet valve before installing the valve. Screw the valve back in place and reattach the hot and cold water hoses, close the top of the washer, turn on the water supply, and connect power back.
Below a diagram. The valve is part 14. Click on the picture to enlarge.
Aug 11, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
CHANGE THE WATER VALVE ON A MAYTAG ATLANTIS WASHER
Unplug the washer
Remove the hoses.
Unscrew the water valve
pop the top.
This manual shows
the procedure
on page 21
Apr 19, 2010 | Maytag PAV3240A Top Load Washer
Top load stacked washer, won't pull water into machine, just
check hoses are not kinked /filter a the fill hose solonoid valve is clear if valve is okay should work...
Mar 31, 2010 | Maytag LSG7806A Front Load Stacked Washer...
I am trying to hook my washer up to a laundry room valve, but it keeps leaking and giving a "NF" code... Is the valve faulty or does my washer need a new hose to hook up to a brand new home's valve?
try changing the washers in the hoses / don't use red outside hose washers/ but hi pressure for fill hoses . home depot should have them . and ck the valve screens at the washer side . clean screens good washers . ( water flow's and washer should work .. mm
Dec 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag top load washer won''t fill with hot or cold water.
solenid valve
may be faulty.
to test disconect from the cold side and atch to the hot side,
the solenid valve is an electronic valve that switched the water on and off its usally atched inside of the back of the machine where the hose attaches to.
http://en.wikipedia.org/wiki/Solenoid_valve
May 03, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Maytag neptune
Apr 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag LAT3600A Top Load Washer Logo
13 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
