Question about GolfBuddy Tour Handheld GPS Receiver
If I start on a hole other than one I have trouble changing to another hole. Also how often should I have to change the rechargeable battery?
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Hi iv got a citroen c4 vtr its cuming up economy mode and wont start is this a common fault and is it a easy fix thank you for eny replies
Economy mode is coming up to prevent your battery from discharge, but it will also cause troubles when your battery is flat - should go away after recharging or changing your battery to new one.
Apr 11, 2014 | Cars & Trucks
Starting troubles, and sounds
You answered your own question It needs a starter
Apr 02, 2014 | 2002 GMC Yukon XL
Nikon l110 date and time reset
I don't think you can change this. For time keeping, there is a little rechargeable battery in the camera. It will take about 12 hours for the battery to become fully charged, if everything is normal. If the little battery is gone, the camera can't keep up the time, causing your trouble. Please check with Nikon, what it will cost if they can repair this. To expensive? start saving for a new camera.
At least I think you gave the little battery enough time to charge. It would be bad, to remove the battery every time you stop shooting. Leave the main battery in the camera for at least one day and check again.
Feb 27, 2014 | Cameras
BATTERY PROBLEM
Ultimate solution is change the battery... because the capacity of battery cells is poor.. this could be the reason if battery is old...
Still u can take a chance by completely removing the battery fluid and replacing it new battery fluid... but keep in mind that, after doing so, u'll need to charge the battery fully before using it in car...
This kind of battery problem is common in all diesel cars, the reason I think is, Diesel engine need heavy torque to start that draws heavy current from battery.. so if you are facing starting trouble for the vehicle, then battery is surely going to discharge frequently...
Still try the solution mentioned above and still the problem persists, then replace the battery with new one.
((I am considering that the battery you are having is 3-4 years old...))
Oct 16, 2012 | 1997 Ford Escort
How to replace battery of wireless laser mouse mi
On the Top on the Mouse u can see the Battery u need to Remove the old Battery's and Replace with New battery see that you use Rechargeable battery because ordinary battery life spam is very less and u need to change the batterys for every 1 month so if u use the rechargeable battery then u need not change battery for 1 month at least for 5 or 6 months the rechargeable battery work and u can keep and spare rechargeable battery when every needed and try to purchase a Sony Rechargeable batterys deepakkumaar.jpg
Dec 14, 2010 | MSI Computers & Internet
Logitech Mouse asking me to change bateries while they are new
The rechargable batteries can start wearing out after some recharges. Try recharging the batteries or get a new set of batteries.
Jan 21, 2009 | Logitech Cordless Desktop EX110
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Clock battery won't recharge
Change to Ni-Mah rechargeables at the highest capacity you can find. If still in trouble it will suggest the internal battery has died - and a replacement is a repair job which will be pricey if feasible So just live without that feature.
Aug 01, 2007 | Nikon COOLPIX L4 Digital Camera
Changing the batteries on the BenQ Wireless Mouse
If you slide down (hard) the panel beneath the 2 clicker keys, you will find a battery compartment with space for 2 AAA batteries7f60d17e-8b58-4076-acc1-563ab4428c0d.jpg
Jul 30, 2007 | BenQ M310 Wireless Mini Optical Mouse
GolfBuddy Tour Handheld GPS Receiver Logo
23 people viewed this question
Top GolfBuddy GPS Experts
ka4iup
ka4iup
Thomas Perkins
Thomas Perkins
Are you a GolfBuddy GPS Expert? Answer questions, earn points and help others
