Question about GE Profile Harmony DPGT750GC Gas Dryer
Dryer only stays hot for about half a cycle.
Dryer stops providing heat about half way through cycle. If I let the dryer rest 12 hours, I have heat, but only about half a cycle again. My only options are a blower motor ($193) or blower motor wheel - per vendor. There is no blower motor controller for the gas model which I have. Should I get the blower motor? If so, can I install it myself - can't find any install instructions for this part. Thanks
  • 3422 Answers
SOURCE: GE Harmony Profile Dryer DPGT750EC1PL not heating & blower not working
HI,
If your blower stops working, the element will overheat and trip the high limit, thats is why you have no heat.
The trick is to find out why the blower isnt working. It should be found under the dryer. Its possible that there may be a loose wire. It could be getting ready to go out. I would run the blower motor, observe it when it stops, then take a voltage reading. If voltage is presnet at the blower motor, and the motor isnt working, then the motor needs to be replaced. If voltage is not present, then we must determine why.
If your dryer is not getting any heat, you need to make sure there is nothing blocking the front of the dryer. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome. Check the coil for continuity with a Volt Ohm Meter. If there's no continuity, it means that the element is bad and you need to replace it. An electric dryer should have it's own separate power line.
When the burner is operating properly, the flame should be clean and blue.
If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
If the ignitor doesn't glow, look for a white or yellowish discoloration, or for a break in the ignitor. If this is something visible, just replace the ignitor. If there are no obvious signs of a break or burnt area, test it for continuity. If the ignitor doesn't have this type of problem, you'll need to determine if the problem is in the control area, or somewhere else within the burner system. Test for 110v getting to your burner assembly.
Here's a test you can perform: Unplug your dryer and then open up the burner inspection panel. Unplugging your burner assembly unit, you want to connect your jumpers for the Volt Ohm Meter to the dryer side of the assembly, not the burner side. Keeping your Ohm meter wires away from the drum area, set the timer to on, set the controls to high heat, and then plug the dryer back in. If there is 110v in this area, you can assume the thermostats in this area are good. If not, a timer, motor centrifugal switch, or other thermostat may be your culprit.
To protect from over-heating, many dryers use what's commonly called a thermal fuse. If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It's about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
You should visually inspect the wiring connections to the dryer from the house regularly. If you're opening the dryer case, give the wiring inside a good visual check as well.
Lastly, never use an extension cord to operate this appliance. An electric dryer draws a lot of power, and the shorter the wiring to it, the better. The power cord connects to a terminal block in the back of an electric dryer. Sometimes this terminal can get burned out or ground to the dryer. Make sure the power is turned off, and look for scorching, burned, or broken connections. For electric dryers, one broken connection might allow the dryer drum and timer to operate, but there would be no heat.
If your clothes are wet then:
This is usually caused by poor airflow. Turn your dryer on and go outside to the vent. If there is not a strong airflow, check your dryer duct vent, lint trap, blower, and also look for clogs and kinks in the vent hose or ducting. Ductwork inside the dryer may become clogged. Use a long flexible lint brush or vacuum attachment to clean these ducts. Make sure the air path is clear from the burner assembly or heating element all the way to the exhaust vent.
Some electric dryer heating elements have two circuits in them. Sometimes one can burn out. If one part is not working properly, this can lead to a dramatically longer drying time. If this happens, you'll want to just replace the whole heating element since the individual circuits are not available separately.
Another reason for damp clothes would be one of the cycling thermostats. These control the temperature in your dryer and when they fail, they prevent the dryer from heating well or stop it from operating altogether. To locate and replace a thermostat, follow the duct work that moves the air through the dryer. A thermostat has 2 to 5 wires attached to it, and the body is black or brown. On the end opposite the wires is a metal plate that is used to attach the thermostat to the duct work.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 07, 2008
ginko
  • 19396 Answers
SOURCE: Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
Posted on May 18, 2008
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
  • 54 Answers
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Posted on Jul 04, 2008
mrboo747
  • 24 Answers
SOURCE: Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Posted on Nov 30, 2008
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer starts and about 5 minutes later stops and lights start flashing
DRYER OVERHEATING: Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Mar 22, 2015 | Dryers
Dryer over heated and stayed hot for 12 hours
sounds like the stats on your element are faulty
Apr 03, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Always on high heat and shuts off after 20 minutes
Check the complete venting system inside the dryer and to the vent outside. Be sure and check for lint & god knows what around the blower wheel. Get everything 100% clean. Insert a thermometer into the vent coming out of the dryer with the vent hose off. Start the dryer on high heat & see if it will go to not over 180% and start going lower like 130% or so if it drops back it's ok . If it don't stop & go down cycle thermostat is most likely bad. The reason it won't start for an hour may be the motor gets too hot. You could put an ohm meter across the connection on the cycle therm and heat it with a small torch or something & see if it will show open after heating. Just a guess lots of things cause these problems. Clean that motor too. Lint may cause it too run hot.
Mar 28, 2014 | Whirlpool Dryers
GE Profile Harmony Gas Dryer not heating/drying clothes.
let me ask you this does the ignitor glow orange but no flame when you have no heat?usually on a gas dryer if at first you have heat and then after 10 to 30 minutes no heat it's usually the gas coils located on top of the gas valve,common problem,after the coils cool down they will work again,that dryer is kind of complicated to work on seeing how it does have two motors in it but you should be able to get at the gas coils,if you send the model number i can look it up for you.but it sounds like you have bad gas coils,the only way to tell is run the dryer,when the heat stops working look at the ignitor,if it glows orange and the flame doesn't ignite you have bad gas coils.
Feb 14, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
Whirlpool gas dryer heats then stops
you will want to do two things
first check you vent exhaust even a small clogg here can be detrimental
then if thats clear
repalcce the coils on the top of the gas valve
they are probaly weakening
they are called the boost and assit
or hold and assit
they sit ontop of the gas valve
Oct 13, 2009 | Kenmore 63942 Dryer
When dryer cycle is done elements stay on
One of the switches that controls the heating element has not closed.
Apr 30, 2009 | Frigidaire Dryers
HEAT
Clean out your vent and filter housing.
Dec 22, 2008 | Kenmore 62602 Electric Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
