Question about Coleman 7990-319p Evcon Gas Furnace Control Board
Indicator blicks 3 times replaced combustion air switch but did not resolve problem. what do i do now?
Air combustion switch was replaced but didn't solve issue indicator light still flashes three times
    Novelist:
  • 189 Answers
There should be a diagnostic chart on the furnace door by the wiring schematic. If so see what the code reads for three blinks.
By the term "air combustion switch" I guess you are referring to the pressure switch. Most diagnostics blinking three times is just a dirty flame sensor. If this is the case the burners will light and go out within 4 seconds. If this is the problem carefully remove the flame sensor and clean gently with emery cloth, fine sandpaper or fine steel wool. Reinsert the sensor and enjoy your heat.
Posted on Dec 19, 2014
Ignition control led 3 flashes
First, make sure that combustion fan comes on and there is nothing obstructing air flow in the combustion chamber. Then, check the tube between the pressure switch and the induction motor to make sure it is connected and not obstructed. Then, replace the pressure switch, part number 60030.
Mar 02, 2014 | Mr. Heater MHU45LP
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
there should be a diagnostic code that will tell you what 3 blinks mean for that model. look on door inside cover. tell me EXACTLY what it does at start up. small draft motor comes on? you see a glow from hot surface ignighter? gas comes on? flame on? it should run in this order.
Armstrong air furnace
Have you checked the flue inlet and outlet to see if it doesn\'t have a wasp nest or bird nest or rocks. check the hose that is attached to the pressure switch and the port on the collector box or inducer fan motor to see if it is clear. if you take the switch off and lightly suck or blow into the port it that will close the switch. If you have a manometer you can check the pressure differential. On the pressure switch it will say what pressure in will close at ...Example .52" WC. or 1.25"WC You would attach your manometer to the tube attached to the pressure switch and start the combustion blower to read the pressure. If you have over the reading and the switch didn\'t make you will need to replace the switch. if you have less than you have to make sure the flue is open. You can check the flue with a simple trick by unhooking the flue pipe from the combustion blower and then check the pressure and you may have to unhook the air intake also. If that doesn\'t work you could have a plugged secondary heat exchanger...... Good Luck.
Nov 12, 2013 | Heating & Cooling
Propane water heater high limit switch keeps kicking out
1) What brand and model water heater?
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake screen using compressed air or feather duster.
With AO Smith, craftmaster, state, reliance, american, kenmore, whirlpool, the air intake is located on bottom of heater. Rheem, richmond, ruud, GE, Bradford white, the air intake screen is located under combustion parts.
Water heaters today require plenty of fresh air. If air intake gets clogged with dust, then combustion byproduct moves up pipe too slowly for amount of fuel being burned, and this overheats combustion chamber.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Add a comment with more information
Dec 13, 2012 | Water Heaters
I have installed ac of whirlpool. after 2 month the indicater of filter started blicking, i called the respected people and made it clean. until the indicater is continuously blicking. the sales person...
If the filter was removed and replaced while the unit was ON, it doesn't sense that it was replaced or cleaned. Turn the Master ON/OFF Switch to OFF, unlpug it from the wall, remove the filter and reinstall it properly. Then, plug the cord back in and turn the Master ON/OFF Switch to ON. The Clean Filter indicator light, should have stopped blinking or will shortly there after.
Hope this helped you.
Jun 20, 2011 | Whirlpool ACC108PS Air Conditioner
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 19, 2010 | Filter Queen Defender Air Purifier
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Coleman 7990-319p Evcon Gas Furnace Control Board Logo
237 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
