Question about Singer CSP1 Iron
Ironing pad Need new ironing pad
2 Suggested Answers
mace1mace
  • 1138 Answers
SOURCE: I NEED A NEW COVER FOR MY SINGER MAGIC STEAM
purchase here
http://www.uksewing.com/product_info.php?products_id=40
Posted on Jan 23, 2011
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Something is stick on ironing surface, how do i clean it?
the best way to get sticky stuff off of the iron surface would be to plug the iron in and let it warm up -- then with warm water use a green or red scotch-brite* pad and scrub it clean -- ( be careful not to burn yourself -- double up the pad )..
if the stuck on stuff is really on there, you can also use a razor blade ( safety blade* ) and at a good angle scrape the sticky stuff off -- ( do this while the iron is off and cold ).
c...
Dec 31, 2010 | Irons
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
Sep 23, 2009 | Hamilton Beach 14977 Iron with Auto...
I have a rowenta iron. When I am ironing the
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
Euro Pro 1005 ironing Cover and Part.
Hello, rslarve, Okay, here are a couple of links that should be helpful: Euro Pro Replacement Cover LC and Pad for EP1010 / 1005
This will link you directly to the purchase page for the ironing cover you want. Sorry, but after extensive searching, it's the only one I could find, so I suggest you get two while the getting is good! Customer Support for Sharkvac Products - sharkvac.com
This link will take you to a web page that will allow you to send the manufacturer an email explaining the part you need. Please, before you send the email, try your best to find your manual and see if there is a part number listed for the part you want. If not, and the old part is available (like—if you have a broken one), check it over thoroughly (perhaps using a small flashlight and magnifying glass to make sure you don't miss it) for any numbers that might be stamped, embossed, or etched into it. Even if they are not part numbers, they may help the manufacturer to locate the one you need. No matter what, send them as much information as you possibly can in order to help them be able to help you—the easier you make it on them, the more likely you are to get satisfactory results.  Finally, here is a toll-free number for the manufacturer's tech-support line: the same "homework" applies before you call it: 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
I hope this helps! Ken
Feb 09, 2009 | Euro-Pro EP1005 Iron
Handle on iron gets too hot to hold onto. Product is an Euro-Pro Ironing Solution. Ironing system includes the iron and ironing board together.
I purchased a silicone heat protector for a pot handle and sewed it together with dental floss around the iron handle
Sep 23, 2008 | Euro-Pro EP1005 Iron
Steam iron
time for a new iron, safety first , you will be surprised at what you can get on sale these days
Sep 01, 2008 | Irons
Rowenta iron model 871 series b shows rust while ironing
My iron spits rust spots on my cloths and need cleaning. I lost the manual in a move. I need help.
Thanks
Shirley
Mar 18, 2008 | Black & Decker D2030 Iron
Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Sep 08, 2007 | Panasonic NI-H10NS Iron
Singer CSP1 Iron Logo
29 people viewed this question
Top Singer Irons Experts
russ davis
ray gallant
L Pfaff
L Pfaff
Are you a Singer Iron Expert? Answer questions, earn points and help others
