Question about Teac SL-A100 Shelf System
I have a Ferguson record player from the 70s which plays songs too fast. What can I do to fix this slight problem?
The songs are just less than a semitone too high because the records play a little too fast, how do I fix this problem?
2 Suggested Answers
SOURCE: turntable plays too fast
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
Posted on May 08, 2008
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Crosley Turntable Repeating little bits?
Is this on all records? if yes! you need to adjust the weight slightly, if the problem is with one record, clean the record in luke warm water and dry carefully, may solve the problem.
Apr 16, 2012 | Crosley CR49 Traveler Portable Turntable...
My media player doesnt detcected my philips mp3
If the device is still detected by your computer, you can open up Mycomputer and look for the device and select format and that shoudl the problem.....
Aug 09, 2009 | Audio Players & Recorders
Songs Sound Distorted
Setup your device to the default settings, and format it, than copy a new music into the device and listen.
Hope this helps.
Jun 24, 2009 | SanDisk Sansa m240 MP3 Player
Turntable speed
There is no pitch control on this unit.
Apr 03, 2009 | Intellitouch Communications INTELLITOUCH...
Playing songs
first thing is to make sure you have the current firmware.
· http://us.creative.com/support/downloads/
Jan 04, 2008 | Creative Labs Zen Micro MP3 Player
Mp3 player plays in fast forward
i have mp3 songs on my desktop when i m copying then in external hard disk or making mp3 its writing in fast sorward format its playing in fast forward format in car system in my laptop plz help me out in my laptop there is vista home premium
Dec 07, 2007 | RCA TH1101 MP3 Player
Fast forwarding
RCA TH1100 Series:
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check
http://support.rcaaudiovideo.com/downloads.aspx?product=25
for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Sep 17, 2007 | RCA TH1101 MP3 Player
Teac SL-A100 Shelf System Logo
23 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
