Question about FUJIFILM instax mini 7 Digital Camera
My film isn't coming out - FUJIFILM instax mini 7 Digital Camera
Having problems with my N90s
when you place the film in the camera & close the door does the film advance ?
Jun 06, 2013 | Nikon N90S 35mm SLR Camera
I have a Nikon FM3 and the shutter opens at the correct speeds but when I put B&W film in it (Kodak TX 400) and develope the film, there is nothing on the film like it was brand new. Help please.
Check to make sure that the film is properly inserted into the take-up spool, and watch the rewind knob and make sure it is turning indicating that the film is going through the camera. Also check to make sure that the multi-exposure lever isn't stuck in the on position by spillage or impact so the camera just keeps taking exposure on one frame and the film doesn't move.
Sep 29, 2012 | Nikon F3 35mm Film Camera
E000007-0000
This is not a problem for the IR-5000 copier. This is an error code for the instant on copier that use a fixing film assembly. This is error indicating that the fixing film isn't turning in the fuser assembly and most likely is damaged and the fixing film assembly will have to be replaced.
Aug 15, 2012 | Canon imageRUNNER 5000 Copier
I am facing frequent tearing of fuser film code 00007.The engg. advised n converted 4570 canon to reduced speed approx 30-35 copies per min. but the problem persists after every 18000-20000 copies .Please...
if the fixing film keeps to wear down rapidly, the problem can be few things.
  1. Maybe the pressure between fixing film and silicon roller isn't good ( replace silicon roller, silicon roller bushings, and execute the nip check in service mode )
  2. Maybe that the fixing film isnt Canon and therefore lower quality.
  3. Maybe the fixing heater ( beneath the fixing roller ) has "nose" or place where the fixing film gets stucked or wraped. Change the fixing film assembly ( Canons film + heather in assy )
  4. TO BE SURE, THE BEST SOLUTION IS TO CHANGE THE WHOLE FIXING ASSY with new one.
Hope that helps!
PS for service manual you leave your e-mail...
Aug 01, 2011 | Canon imageRUNNER 4570 Copier
My LG LDF7920ST dishwasher is 2 years old. Suddenly its leaving heavy gritty white residue inside cups. This isn't just a film. The first time, I thought maybe white house paint had gotten into the cup...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 06, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
What does flashing E mean?
E means that the film isn't loaded in the camera properly, try reloading the film and that should fix the problem.
May 11, 2011 | Fuji Photography
I recently shot three rolls of color film with my ZX-7 in auto pict mode and all the negatives turned out blank (underexposed). What happened?
lens cap ? ;-]
Did you have the asa film speed set correctly? Thats usually the cause unless your battery isn;t quite right.
Mar 23, 2010 | Pentax ZX-7 35mm SLR Camera
I had new film put on back window of my 1997 Toyota Camry and I now have a black line going up through the middle and a black line on the side, What is this? I don't feel safe driving. Altha Breininger
your puted the new film your sef or by another man?
if is the second , you must know that the film that is puted isn,t one piece all,
and the man that puted the film have joint together in the midle of your window and in the side the film(films beter, and from your prescription i think you have 3 pieces) so isnt problem, only may obstruct you to beter see from the center mirror that you have in your up right.
Mar 29, 2009 | 1997 Toyota Camry
FUJIFILM instax mini 7 Digital Camera Logo
16 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
