Question about Video Cameras
Sony hdr-hc7 camcorder will not load tape - Video Cameras
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Posted on May 06, 2009
tbreeze47
  • 3083 Answers
SOURCE: Hi I have a Sony
The way camcorders and cameras focus is by using tiny electromagnets attached to the focusing ring, and signals from the infrared sensor focus the pic or vid. When dirt, dust, sand, or lint works it's way into the lens assembly, the focusing ring can get slightly jammed. You can try to spray some compressed air into the lens area, in the hope of freeing it up.
Aside from that, there could be an intermittent ribbon connector (slightly loose), or any other number of crazy things that can happen with solder joints and wires, or components.
If the compressed air doesn't fix it, the unit will have to be troubleshot and serviced. Get an estimate first, since it can be costly.
Oh, one other thing. Make sure you have clean battery contacts, both on the unit, and battery. Clean them with a qtip and at least 90% isopropyl alcohol, or a pencil eraser. Slightly oxidized contacts can cause intermittent problems.
Good luck, and hope this helps.
Posted on Nov 26, 2010
Sony HDR models that the carriage won't close is caused by the mode switch on the chassis. The mode switch controls the cameras function for loading and loading of the cassette. Basically tells the electronics what is happening. This becomes dirty and causes the chassis not to complete it's cycle on eject. Thus staying open. It has no idea where the mechanism is at this time. It can be cleaned and realigned but the chassis needs to be removed to get at it. Definitely a service depot repair. Sorry!
Posted on May 02, 2011
Rick Riggins
  • 1812 Answers
SOURCE: I have a sony hdr-hc7 hd camcorder.. I was using
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Aug 21, 2011
SOURCE: sony hdr-hc7 camcorder. lcd screen
I'm looking for answer too. I have the same problem. Mine still work/stop scrolling when the LCD is flipped out and closed to the body.
Posted on Aug 28, 2011
Why i have to set clock after changing battery everytime
you need to change your settings to auto date and time update
Nov 24, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
My tape mechanism won't close. I put the tape in, and "pinch" it into the camera, but the pinch won't stick, as if there's something blocking the tape from fitting as it should. I've had this...
The timing cam is misaligned. It will need to be disassembled and realigned. Do not force anything to avoid further damage. Take it in to a camera shop.
Oct 30, 2010 | Sony Handycam HDR-HC7 Mini DV Digital...
Tape stops for a second or two no sound, picture paused
The heads are dirty and the tape is binding to them. Buy a head cleaning tape and run for the recommended time. Or if no cleaning tape available, buy a recommended cleaning soution and gently clean heads or head roller with an earbud. Heads are always bright chromium finish, and they are positioned internally to align with the central area of the tape cassette...
Apr 07, 2010 | Sony Handycam HDR-HC7 Mini DV Digital...
TRV-520 tracking problem on playback
It could be difference in the company's camera.
Dec 17, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Sony HC7 flip out screen video rolls and no or limited touch scre
You can purchase a new LCD Flex cable for a Sony HDR-HC3 (Same as HDR HC7) from e-bay for 27 US$.
You can also download free service manual from internet that explains simple repair.
Sep 17, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
What is the best way to delete all taping from my mini dv's
You can use a powerful magnet swipe it up against the side of the tape several times or you can just tape over them again or you can put the lens cap on the camera and press record
Aug 28, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Loading tapes
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Video Cameras Logo
16 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
