Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Roller brush wont spin eureka
Burning smell, the brush wont spin even on high carpet level
reddevil6
  • 1673 Answers
SOURCE: Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Posted on Jan 22, 2008
SOURCE: Smell/suction
Ours started smelling too, and it seems that the plastic end on the roller brush was melting. In process of finding rollerbrush for it now
Posted on Jan 25, 2008
SOURCE: In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Posted on Jun 26, 2009
Vac Belts
  • 701 Answers
SOURCE: My Eureka The boss Smartvac Model #4870 roller
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Posted on Dec 11, 2009
Vac Belts
  • 701 Answers
SOURCE: I have a Eureka Altima vacuum cleaner that doesn't
That means that you need to replace the belt. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Posted on Jan 02, 2010
I have a new eureka vacuum AS1101 and the roller brush wont spin. The S belt doesn't look worn. When the clutch is engaged the second smaller toothed belt doesn't run. Are the larger and smaller pulley...
The answer is you small wheel that is burned or melted is a result of having the carpet height setting too low for surface being vacuumed. Because of that, it causes the brush assembly drive to work harder. The smaller of the two wheels has..had a piece of plastic to hold it against the shaft to allow it to turn. It will have melted off and will not spin. The belts and even the other larger wheel will work, but just not engage the smaller and allow the brushes to turn. The part needed does not sell by itself, you would need to purchase the on/off wheel assembly. OEM Part # 84708. It is about $30 on amazon shipped. new-eureka-vacuum-as1101-roller-brush-imoup3n5z40rufpnmkir3rab-3-2.jpg
Jul 17, 2014 | Eureka SuctionSeal Bagless Upright Vacuum,...
What is wrong...My Eureka commercial vacuum C2094g smells like burning rubber, replaced belt (style RD) but it was smaller in size and very hard to put on. Am I using the wrong belt? it looks like the...
Replace the Roller Brush. Sounds like bearing in it is locking up and the the belt is slipping and not turning the Roller Brush as it has a locked up bearing. You will need to go ahead and get a replacement belt just in case you have stretched the older belt to a bigger size. I had this same experience with a Hoover and it solved my problems of "rubber burnt smell".
Apr 27, 2014 | Hoover S3765-040 WindTunnel Bagless...
Roller brush spins
The roller brush will turn as long as the sweeper motor is running no matter what brand you have. Turn it off as you return it to the upright position.
Dec 29, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka burning smell
Hi, it's Cindy from Crucial Vacuum.
Since you have replaced your Eureka 4870MZ 9200 Proheat 2x vacuum's belt, the issue may either be caused by your roller or the position of your belt. It sounds like as soon as your vacuum is lowered, the belt is either slipping or wear on the end caps is causing your roller to stop. This will cause the burning smell since your motor is now straining against the abrupt stop. Try taking off your roller and checking the conditions of the end cap or try to reinstall your belt. I have included an instructional video: http://youtu.be/rji0fl9hytY
You can purchase direct your replacement brushroll from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-smart-vac-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 20, 2013 | Eureka The Boss SmartVac Upright Vacuum...
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brushes do not spin when it is on low carpet you have to have the knob on high carpet for it to work.
That means that the belt is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet. The lower the setting the more resistance. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Nov 19, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
23 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
