Question about Dryers
Squelling noise Have a Kenmore smart heat quite pak 4. Making a squelling noise. Could it be a belt or bearing?
  • 55 Answers
SOURCE: kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Posted on Mar 10, 2008
  • 1028 Answers
SOURCE: Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Posted on Aug 04, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
  • 91 Answers
SOURCE: Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Posted on Jan 04, 2009
  • 1214 Answers
SOURCE: Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Posted on Jan 26, 2009
Not doing anything, making a ratchetting sound, won't wash, spin,rinse, anything
Have you checked the drum for residue that may actually prevent it to spin? try to check the cycle selector as well and try to load more clothes... keep us posted, thanks for using fixya!!
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
My Kenmore elite smart heat quiet pak 4 automatic dryer model 110. 87872603 shut off during drying cycle and showed service code f23. The dryer was extremely hot.
call sears service . sounds like the exhaust blower has failed you or perhaps the filter us plugged and needs cleaned out which should be done before or after each use
Jun 16, 2015 | Kenmore Dryers
Dryer starts then makes aweful noise then stops timer keeps ticking then when you try to start it again it doesnt do anything
If it is a grinding noise then it is probably a bad bearing. If it is more a squell it could be the belt slipping in addition to a bad bearing. If it is a banging sound it could be the belt.
Jun 19, 2011 | Dryers
Kenmore elite oasis dryer quiet pak 2 making loud screeching noises-
Either your glide pads that the front of the drum rides on are worn out, or the rear drum bearing are worn out
Mar 24, 2011 | Kenmore Dryers
Squelling noise from aternator or belt tensioner
Good Evening, I would hope it is the belt or the alternator first because the belt tensioner is a bear to replace. I would recommend taking a better look at your belts first 80% of squeaking and squealing are from dirty, and old belts. And while you are changing it out you can spin each pulley by hand and see if there is one specifically making noise and go from there. Hope this helps.
Oct 02, 2010 | 2000 Dodge Neon
1992 Pickup: loud squelling sound under hood when started...
Sounds like a loose belt.
There are a few things that can cause a belt to slip like that.
The belt could be not tightened all the way. If it uses a sepentine belt with a tensioner, the tensioner could be bad. If it is not a serpentine belt, then you will have multiple belts and the one that is making the noise can be loose. Use something to pry it tight and tighten down the bolts holding the component th belt goes to.
It can also be a bad pulley. Pulleys have bearings inside of them, at times the bearings will go out and make the pulley hard to turn. You can usually find this easily by taking the belt off and turning the pulley with your hand. If it is hard to turn or makes a grinding noise when turned...it is bad and needs to be replaced.
Old belts can also cause this along with a belt that is wet. There is a spray on Belt Dressing that helps get rid of noisy belts, but I consider that a bandaid to a bigger problem.
May 03, 2010 | Toyota Cars & Trucks
Squelling belt
Yes, it could be.
The fact that it quiets might mean that the internal seals are leaky allowing water to enter bearing surfaces that dry, then squeal.
Look for any traces of the water pump starting to drool; there is a hole (normally underneath) that allows water to drain if the seals fail.
Aug 24, 2008 | 2001 BMW 325
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
