Question about Toshiba e-Studio 255SE Copier
File storage error while scanning - Toshiba e-Studio 255SE Copier
IBM Travelstar usb 2.0 - when connected to pc get error msg - problem with drive need to scan - WILL scanning ERASE FILES THAT ARE STORED ON THE usb drive
the scan is just a program reading the files and folders either in the computer or storage device
normally it is done by the security program ( windows fire wall) or what ever program you have installed
it reports on any problems found and waits for your decision
if you run a system check, that is different as it will rectify any program faults as it goes not files or folders
it is always advisable to scan usb sticks when installing as that is a favourite way that hackers get into a computer
although the usb stick may be in your control all the time , downloads from your own computer can transfer a problem via usb stick
As for your concern---scanning will not change any files or folders but will report on any faults to you
Dec 31, 2016 | IBM Computers & Internet
How can solve disc error in e 72
If you are using Windows please plug your device in Mass Storage mode and try:
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
Nov 07, 2014 | Nokia E71 Smartphone
Can not scan due to a file storage error
If you are scanning to folder, you will need to view scan log in top access for failure reason such as wrong username or path to the folder. You can log in to top access by entering the copier IP address on the web browser.
Aug 22, 2014 | Toshiba OEM ESTUDIO3040C 30 PPM Color/Mono...
My deleted file is in the sd card.. can the phone memory or whatever storage it has in the phone can recognize the files in the phone memory? -- is the phone memory or any storage of phone can read and...
Usually the SD card is a secondary storage device ... and separate from the (internal) phone memory. To determine / test this, see if your phone still have (some) information when you remove the SD card from the phone... e.g. your telephone contact list, etc.
Yes, you can try to recover the "deleted" file on the SD card using a PC / laptop ... using a data recovery utility/tool (on your PC) to scan the storage space or "undelete" that deleted file..
If your phone can be attached to a PC (e.g. via USB), and if your PC recognizes the "storage" disk on your phone as an "external" disk, you may also be able to use a data recovery utility to scan the storage space or "undelete" that deleted file.
Nov 04, 2013 | Samsung GT S3850 Corby II
Having corrupt files errors, tried chkdsk it states read mode only
When you run CHKDSK/F from windows, a reboot is required to scan and fix the errors as it must run in DOS or it can't work properly.
Try again or better still, format with the system file and copy CHKDSK from your windows to a USB storage device or CD and run it from there. If the device or CD is formatted as a bootable device, the notebook should boot from it in DOS and run correctly.
Hope this helps
Nov 20, 2010 | HP Computers & Internet
How can i save a scanned file as an image on my desktop? for example when i finish the scanning by pressing the scan button it appears "an unexpected error ....etc" so i cannot complete the...
You have to associate that button, with a storage directory, you must set up the preferences, and tell the scanner where to save the scanned file.
Jun 10, 2010 | Agfa SnapScan 1212u Flatbed Scanner
What does Windows Vista error 0x00000005 mean?
Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
( ERROR_ACCESS_DENIED == GetLastError() ) )
// Access Denied: Maybe the file system is not ready yet.
tries++;
if ( tries > 4 )
break;
Sleep(500);
// It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
How do we set up proper ftp server connection to receive scanned images with our Toshiba 232. the current file path is \\10.0.1.5/Scans\ but when we try to scan we get a FILE STORAGE ERROR. we have entered...
the path is all \'s not /'s. 10.0.1.5 needs a shared folder named scans and the copier needs a users valid login name / password for the computer sharing the scans\ directory.
Apr 01, 2008 | Toshiba Office Equipment & Supplies
Toshiba e-Studio 255SE Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
