Question about Mitsubishi WD-73C9 73" DLP TV
Replaced bulb and now tv wont turn on. Power light flashes orange
techman
  • 3130 Answers
SOURCE: replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Posted on Jul 10, 2007
  • 179 Answers
SOURCE: Status Light flashing yellow after replacing the bulb
your air filter cover is loose or not on.
Posted on Dec 18, 2008
  • 11 Answers
SOURCE: recently my wd-52327 said it needed new
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Posted on Jan 20, 2010
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
hardrocko
  • 1476 Answers
SOURCE: Just replaced lamp, when we
ljanicke,
From your description of the lamps and after looking at the error chart for the unit I believe that you have a problem with the lamp door. There is a switch on the cover which can get moved or misadjusted while replacing the lamp. Sometimes the door is just not closed properly. I have a tip at
http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which should help you solve the problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 09, 2011
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
TV wont turn on
The main power supply is failing or it is shutting down because of a fault on the output side of it and it is trying to protect itself from overload which can cause a fire. Contact Zenith customer service and describe the problem, particularly the flashing LED which may be giving you an error code.
Sep 04, 2009 | Zenith E44W46LCD 44" Rear Projection...
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
Orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
Dec 19, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Power slow start/bulb light
Did you get the exact replacement lamp? Some have 1.1 arc gap some have 1.3 they wont interchange. If you got the exact lamp and your trouble is still the same. It could possibly be your ballst.
Jan 16, 2008 | Televison & Video
Mitsubishi WD-73C9 73" DLP TV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
