Question about Diamond Audio Car Audio & Video
I want to know how to fix a blown up diamond audio subwoofer
My subwoofers are blown up
  • 4 Answers
SOURCE: Blown 6x9 subwoofer???
Any speaker will work. It's better if you put in the same kind, but if it's just a stock system it shouldn't matter.
Posted on Jan 10, 2008
Drummernick
  • 440 Answers
SOURCE: Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Posted on Feb 11, 2008
bugpowder
  • 28 Answers
SOURCE: Audio Out Fixed/Variable
Is your subwoofer amplified or passive?
You clearly understand that you need to use a variable line out to control the subwoofer volume via the TV. As the setup seems reasonable, I'm wondering if the subwoofer is getting a signal, but that it is at line-level and not internally amplified by the subwoofer speaker. Generally, if the subwoofer must be plugged into an AC socket in the wall, it has an internal amplifier and can be fed line-level audio. If it is "passive", it has no amplifier, and it must receive an amplified signal (over speaker wire) from an amplifier (or integrated receiver). TV's don't generally have connections to send out an amplified signal.
If the subwoofer is indeed amplified, then this is obviously not the problem, but it's the first thing to verify given the information provided.
Posted on May 12, 2008
  • 3 Answers
SOURCE: MA Audio MA 1200XL Car Subwoofer
that subwoofer has dual 4ohm voice coils, if your amp can handle 2 ohms, you would put a wire from the positive (+) on the amp to the positive on both connectors on the sub, then hook the negative (-) on the amp to the negative on both the sub connectors that will be a 2 ohm load on your amp make sure your amp at 2 ohms is not more than 600 watts RMS or 1200 max.
Posted on Jan 08, 2009
  • 191 Answers
SOURCE: Blown subwoofer
"Is there any way to repair voice coil?"
the simple answer is no.
the long answer is you could try contacting the mfg of the sub and see if you can order a new foam ring, cone and voice coil to replace the one you will have to destroy to take it out.
Posted on Mar 16, 2009
My alpine bassline 12inch speakers stopped working are the blown
If a car subwoofer is blown, there may be scratching noises, but a subwoofer that won't push down has definitely gone bad. Find out how to use a digital voltmeter to test the positive and negative terminals of a subwoofer with help from the manager of a car audio store in this free video on car audio and subwoofers.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Sep 07, 2015 | Alpine Car Audio & Video
My bassline 12 inch. Speakers stopped working are they blown
Either the capacitor or the speaker or both items are defective. If the capacitor is defective, the speaker could still be good or bad.
Sep 07, 2015 | Car Audio & Video
What is the best enclosure for the diamond audio tdx12d2 subwoofer
Personally for a sealed box i would go with at least 1.2 cubic feet inside volume.
A 19" x 14" x 17" box will give you a volume of 1.6 cubic feet (most common).
You can do the math by H x W x D then divide that # by 1728 (for 12" speaker) to get your enclosure volume (cubic feet).
The best enclosure depends on what your looking for in bass response.
Jul 05, 2014 | Diamond Audio TDX-12D2 Car Subwoofer
Need a wire diagram on diamond audio m612d2
run possitave to possitave and negative to negative on speaker an 1 side only to amp
Nov 11, 2013 | Diamond Audio D610D4 Car Subwoofer
No sound from speakers has a fuse blown
If fuse has been blown means power capacity of the subwoofers exceeded the actual power transmitted.Subwoofers capacity cant hold on to the actual power transmitted.If you replace a new fuse check first if internal circuit was not damaged .When a fuse blown out its an indication that something wrong happened within the circuit.Check first subwoofer line if there was short circuit using a tester.Select OHMS mode and try to check both lines.If no movement it means you have it check to a service technician to fix.
Jun 21, 2011 | Car Audio & Video
Brand new subs sound blown? wireing?
crackling noise or really bad distortion check wires and if blown send it to alpine
May 16, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
Vibe subwoofer not powering on
you could of blown the amp. check the fuse in the amp to see if its blown and make sure your getting good ground and positive connections
Mar 23, 2010 | Vibe CBR10 Car Subwoofer
KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Dec 26, 2009 | KLH ASW10-120 Subwoofer
MY SUBS WONT FLEX
your subs are probably blown, or have a blown voice-coil. push on them when they are of and see if you can hear a scatchy noise like wires scraping. if you do they are blown. get back to me
Oct 19, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
49 people viewed this question
Top Diamond Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
