Question about A.O. Smith BTH-199 BTH-199 100 Gallon 199,000 BTU Cyclone Xi[REG] Commercial Gas Water Heater
Blower motor stays running - A.O. Smith BTH-199 BTH-199 100 Gallon 199,000 BTU Cyclone Xi[REG] Commercial Gas Water Heater
Noisy barring motor
bradford white blower . Sir this link will provide you with a variety of sources to buy the blower. The average is far below your quoted target. Since this is a nut and bolt with a direct plug or 3 wire assembly, bradford white blower 239 40614 00 . Here lies a different price point.
If this blower is out of warranty and its been running a long time. The value of the direct replacement is a far better choice to average, although more, odds; are to revisit it sooner than later without a direct replacement.
If you need help to do this job? It can be a do-it -yourself. Make sure the unit is locked out and give it a whirl. If not? The replacement is approximately 2/3 that of your suggested quote. The ball is always in your court.
Be safe. Carbon Dioxide does not discriminate, you never hear anyone from the cemetery complaining. If this is iffy. Get a technician. The extra 1/3 may justify the worth of a life investment. Fare. Well.
Apr 17, 2014 | Fasco Bradford White Water Hot Heater...
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
Keeps giving a code of ops on boiler and will not kick blower on
Are you certain this is a boiler? Furnaces use blowers; boilers do not.
Could you be referring to an induced-draft small blower motor that normally runs immediately on a call for heat?
Is there an electronic control board measuring about 6 inches by 8 inches visible?
We can help if you give us a model # and brand name. Does it operate by oil, natural gas, or propane (LP)?
Feb 02, 2013 | Water Heaters
I have a Rheems Criterion Furnace and the main blower does not kick on any more. The ignitor coil glows, the burners kick on along with the venting fan and stays on for roughly 1 minute. The main blower...
Yeah i would change out that board .Should be a 3 amp fuse so maybe as simple as that but if not a cycling blower motor is a tell tale sign of curcuit board
Nov 21, 2010 | Water Heaters
What causes soot build up in burner chamber
Sounds like you're not getting enough combustion air.
If you have a draft motor or blower make sure it is running.
Apr 30, 2010 | Fasco Bradford White Hot Water Heater...
My hot water tank won't start, i can hear humming sound from the blower, but blower doesn't run, ant it does no heat.
If the blower will not run, then the unit will not fire up due to a safety hazard. If it is a capacitor start motor, then you may have to replace the capacitor, otherwise you will have to install a new blower motor. Hope this helps
Apr 03, 2010 | Fasco Bradford White Hot Water Heater...
The power vent blower on my hot water tank will not shut off.
If the blower continues after the end of the burn cycle it is the cool the heater down. Over running would indicate a defective end cycle temp relay.
Good Luck, Phil
Nov 14, 2008 | Water Heaters
A.O. Smith BTH-199 BTH-199 100 Gallon 199,000 BTU Cyclone Xi[REG] Commercial Gas Water Heater Logo
Top A.O. Smith Water Heaters Experts
bobalix
rdjagger
Mack Baxter
Are you an A.O. Smith Water Heater Expert? Answer questions, earn points and help others
