Question about Plumbing
Presure tank for well pump leaks wtaer at stem
Pump is short cycling check pressure with tire gauge water leaks out
    Genius:
  • 1,114 Answers
The pressure tank will need to be replaced. Water coming out of the air valve stem indicates that the bladder is rupturesd
Posted on May 12, 2014
SOURCE: Watering system pump cycling off and on rapidly. .
Still need help. No responses!
Posted on Jun 30, 2009
  • 1114 Answers
SOURCE: flotec 42 gallon water tank - short cycling and
These holding tanks are pre charged with air which in turn pressurizes the water. The tank has a bladder and an air valve on top. The pre charge ,over time, loses pressure, and the tank has to be pressurized again.
  • The well pump needs to be turned off.
  • The water has to be drained from the tank
  • Air is put into the tank from the air valve on top of the tank, and is measured with a tire air gauge.
  • The pre charge pressure is set to two psi below the pump cut in pressure.
  • In other words if your pump kicks on at 30 psi, the pre charge pressure is set at 28 psi. If the pump kicks in at 20 psi, the pre charge is set at 18psi, etc.
  • After you pressurize the tank, turn water back on.
  • If water comes out of air valve on top of tank, then the bladder is ruptured and you need a new tank.
  • Hope this helps!
Posted on Jul 08, 2009
  • 512 Answers
SOURCE: MY WATER FROM OUT OF THE PRESSURE TANK SMELLS HORRIBLE
Put a mixture of 1 cup bleach and water in the tank, let it set 24 hours, rinse well and see if that gets rid of the smell.
You didn't say what it smells like.......
Posted on Sep 03, 2009
SOURCE: Cabin pump, primed fine only goes to28psi and keeps running
Sounds like the injector nozzle is plugged. This nozzle is directly inside the influent line on single line jets and down in the well on two-line jets. I'm assuming you have it primed correctly. If this happened suddenly the it'd definitely the injector nozzle. It it was a gradual process over time then I would say it's either a badly worn nozzle or worn impeller.
Posted on Sep 08, 2009
  • 523 Answers
SOURCE: gould 1/2hp submergible well pump cycles on and
My first thought was that of a water logged tank which causes short cycling, from your notes the tank is good (the tank may be partially water logged though) If the tank is ok and your getting short cycling (and the switch is good) I would guess your check valve down the well has failed. As the pump creates pressure then shuts off the water may be going right back down the well causing the pump to cycle again. This could also account for the poor water pressure as the check valve may be stuck slightly open allowing the system to loose pressure but only allowing a small amount of flow by when running. There could be a leak within the pumps drop-pipe and your loosing pressure through this leak. I expect you'll have to have the pump pulled.
I hope this may have helped,
Tom
Posted on Oct 12, 2009
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
Apr 06, 2014 | Utilitech Plumbing
Pressure switch cycles on off
Check your pressure tank, sounds like bladder has a leak. Unscrew cap on valve on pressure tank (looks like valve on car tire where you add air to tire) turn cap upside down and use, or small screwdriver to depress valve, if water comes out bladder has burst and replace pressure tank. If not then check bladder pressure with tire gauge. Correct settings are clearly posted on pump. Then add air to pressure tank or remove air to correct pressure. Use a accurate pressure gauge.
Jan 29, 2014 | Plumbing
High Electric Bill due to Well Pump Cycling On Frequently
The short run time of the pump indicates very litttle water volume is needed to reach to turn off pressure. To me this indicates you may have two problems. There is a leak somewhere in the system that allows the pressure to drop to the turn on point. Any check valve will fail eventually so barring any other leak that is your problem. I would think only one check valve is needed in the system so the second one may have been added to crutch the first one leaking. Normally the one check valve is placed on the pump before it is attached to the well pipe. The pump must be removed from the well to accomplish the replacement.
The second problem has something to do with the storage tank. If the pumps runs whenever you open a faucet or in your short cycle situation, then your tank is way too small or it is "water logged". Assuming it has been sized correctly, which means at least 20 gallon capacity then air needs to be added to the tank which will compress when the pump adds water until the high pressure setting is reached. When water is release to the house the air will expand until the low pressure setting is reached and the cycle repeats. The point here is that a significant quanity of water flows between pump cycles.
If your tank was installed in perhaps the last 20 years then it is likely a bladder type whitch contains the water so it never comes in contact with the steel tank, preventing internal corrosion and leaching of metals into the water. If the bladder has failed then the formally isolated air will have been absorbed by the water and your short cycling condition develops. That is what happens in non bladder tanks so air needs to be added periodically. I think all bladder tanks have a car tire like valve stem attached to the tank so that the opperating pressure can be set by the manufacture. The valve stem rairly leaks so bladder failure causes the loss of the air in the tank. There should be a label on the tank specifying the factory pressure. Use a tire gauge to test for the proper pressure. Add air if it is below setting.
Jan 07, 2013 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Gould 1/2hp submergible well pump cycles on and off constantly. low to no water pressure .The pressure switch remains in the closed position. Power to pump side of pressure switch good. pump runs 15...
Tom
Oct 10, 2009 | Plumbing
Water pump cycles to often. When pump turns on, pressure gauge shoots up to 50 lbs right away without pumping much water.
Sounds like a well fed system with a pressure tank that has lost its air charge. Check for a water tank with a tire pressure type stem fitting, should also have a pressure gauge. Most newer tanks have a rubber diaphram inside to keep the air and water from mixing, but a lot of older ones don't and the newer ones will develope a leak that will produce the simpoms you describe. Try adding a few pounds of air pressure to the top of the tank and check for leaks. Warning: Compressed air can escape explosivly if the tank is badly rusted out but if your water pressure goes to 50# without the tank leaking, it should be safe to add up to 25# of air. The air charges the water system and allows the pump to shut off until enough water is used to lower the pressure back to set points on the control switch. It's not a good idea to adjust the set points on the switch unless all parts in the system have been checked for safety to the new pressures.
Aug 13, 2009 | Water Heaters
Under sink tank on older water filter onlyy produces 2 qt at one time. it use produce 1 gal. we have lime iron promblem water 3 flter culligun system under sink water filer system over20 yr old filters...
I am assuming based on your description that the system you have is a reverse osmosis system. If this is true, you most likely need to recharge the air pressure in your RO storage tank. I have included step-by-step instructions below. If you find that your tank is not holding air or the tank will not empty completely, the bladder inside the tank may be broken and the tank will need to be replaced. I have included a link to our selection of RO tanks as well. To recharge the tank you will need a bicycle tire pump and a tire gauge that will be capable of reading below 10 psi. If you don’t have one that reads in single psi increments, then a meter that starts at 5 psi will work.
http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
1) Close the cold water feed valve (if you can’t locate this on your system, you may be able to turn off the cold water to your sink)
2) With the RO tank valve on, locate the valve stem on the bottom or side of the tank. (this will look like the air stem on a bicycle or car tire)
3) Remove the stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave the RO
faucet open throughout the entire procedure)
5) If the current tank pressure doesn’t empty the tank, apply tire pump to valve stem
and pump a few times. Flow will increase and then gradually decrease as
pressure equalizes. Do not overcharge the bladder during this procedure.
6) Repeat step #4 and #5 until tank is completely empty. (Tank is empty when additional
pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5
& 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem
10) Open cold water feed valve.
11) The water is useable immediately; however, tank will take a few hours to completely fill.
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Jul 17, 2009 | Culligan Tools & Hardware - Others
Flotec 42 gallon water tank - short cycling and changing water stream...do I need a new tank or could it be another problem?
  • Hope this helps!
Jul 06, 2009 | Flotec Corrosion Resistant Shallow Well...
I have a ge reverse osmosis filtration system and recently lost pressure and tank capacity. I have only had the system about a month and my water has been tested fine. I did leave town for 10 days, could...
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric Profile Smartwater Ultra...
Have a kent r/o system dont know how to hook it up is there any way someone can help
Necessary Supplies:
3) Remove stem cap.
procedure.
Apr 13, 2009 | Culligan Under Sink Water Filter
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
To recharge RO System Tank:
3) Remove stem cap.
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
Mar 19, 2009 | Culligan Under Sink Water Filter
Plumbing Logo
60 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
