Question about Eureka 2971AV EZ Kleen Bagless Upright Vacuum
Eureka ez kleen vac, no suction
No suction
MATRIX_MMX
  • 209 Answers
SOURCE: eureka upright vac. no suction
Dear wymanwong
Righteo, your problem is not exactly all that straight forward as i dont have a great deal of information to go on with regards to this type of issue and this make/ model of vendored appliance, so I will begin by explaining how the typical vacumn cleaner functions (in relation to your issue) and what can cause a fault of this kind.
The vacumn cleaner overall (unless is a liquid cleaner as well as a conventional dry suction unit) has the function of providing suction into either a chamber or bag which is either filtered or emptied, and the effects of loosing suction usually are effected by faults within filters, or directly through the motor that is normally powered through 240V~ (AC) within the UK or
115~ (AC) USA. Suction can also be lost through blocked exhaust outlets through the vacumn unit and also through any perforations or tears to a bag/ container that is used in order to maintain constant suction and storage of particles/ vacumned waste.
Now to investigate the fault you have in regards to loss of suction within your unit.
Firstly You should query the suction motor and the copper windings as these are both electronic and mechanical components that can be affected not only by general wear and tear, but also by various ingressions (such as water and liquids). Also heat can play a major role here, as motors can spin up to a large amount of revolutions per minute (RPM) and this will cause heat build up, add this to the fact that the windings inside most electric motors are made of copper, and you can quite easily discover that the motor will "burn out" as copper will break down at somewhat lower temperatures than other electronic components (this is also more likely as the casing of a DC/ AC motor is contained within a steel structure which is a good store/ conductor of heat).
The other factor that should be considered with vacummn failures is also associated with exhaust impedances. In otherwords, if outlets and filter channels are blocked, then overloads through the motor wiill be likely and the entire system may cease altogether.
In addition to this, investigations of the power supply and any power transformers within the unit should also be queried, along with any rectifiers (used for converting an AC signal to a DC signal for use with DC motors if necessary), as faults with these can occour even over short periods of time.
If queriying these components have returned no results to the fault, then there is always the option of attaing the service sheets for your appliance from the manufacturer/ vendor of your appliance. The best thing to do in this case is either to go to http://www.google.com or to the website that is listed for your manufacturer/ vendor. Now if google if your option, then there are a few keywords which will assist in your search for your service sheets and they are to simply either type your appliance name followed by the words "service sheet" or "repair manual" In addition to this, you can always contact the manufacturer/ vendor of your appliance directly by telephone and delegate with them in order to request user manuals and servicing guidelines, and given the fact that you have a small appliance, if you mention that there is a possibility you would order any spare parts through them, then i really cannot see a reason why they would decline offering you the servicing guidelines/ manuals at a low cost.
Now there are other things here that can be investigated, but in order for me to dfo this i will need full details of your appliance model number and maufacture code, along with full details of the fault, as accurate as possible. Also photographs of either the machine or any/ all of the internal components will greatly help as direct visuals will aide not only in the identification of your make/ vendor model, but also may give a visual clue of what could be defective within your appliance (for example scortch marks on the wiring that supplies your vacumn motor etc) But any pictures supplied will need to be of a high resolution and quality.
Well I do hope that this brief explanation will provide enough information for a fixya or even a total unit overhaul in the most cost effective manner, in addition to this i do hope that i will hear from you in the somewhat near future as so i can find out more about your fault and indeed if you have managed to resolve it elsewhere (and even how this was done).
I am here most days and nights and any contact to and from me will ensure that I endeavour to resolve your technical issue in the most appropriate way for you.
In the meantime, i do hope you take care, and look forward to hearing from you soon
yours sincerely
Oz
Here on demand for all your technical needs
Posted on Apr 14, 2008
SOURCE: We have the Eureka EZ
THE HOSE BETWEEN THE DETACHABLE WAND AND THE BRUSH ROLLER AREA MUST BE CLOGGED WITH CARPET FIBERS. CLEAN IT OUT AND IT SHOULD WORK.
SFC ANDERSON, RICHARD T US ARMY
Posted on Jan 09, 2009
SOURCE: The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
Posted on Dec 16, 2009
  • 9 Answers
SOURCE: Eureka EZ Kleen 97A battery?
You might try here: http://www.vacpartswarehouse.com/Eureka-97A-stick-s/2254.htm
Posted on May 23, 2010
  • 3287 Answers
SOURCE: how to install belt on eureka ez kleen vacuum
While this answer is not for your specific model vac, most belt changes are very similar and pretty straight forward. Have a look at this video to see how it's done.
Posted on Oct 19, 2011
How to install belt on eureka ez kleen vacuum
Oct 19, 2011 | Eureka EZ Kleen Cordless Lightweight Stick...
Instruction manual
Check this link if that your user manual
http://www.allbrands.com/misc_files/pdfs/eu430SeriesGuide.pdf
Hope that helps........
Jul 30, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Oct 18, 2009 | Eureka Vacuums
We have the Eureka EZ Kleen upright. We have suction through the hoses but not the main vacuum. The brush turns fine but the vacume does not **** anything up.
Jul 08, 2008 | Eureka Vacuums
Eureka Wide Track Superlite Vacuum
Eureka doesn't make these motors available. Best to just replace the stick vac with a new one.
Jun 14, 2008 | Eureka 421A EZ Kleen Bagless Stick Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12164&thid=669867
Posted by mjtnm on Jun 14, 2008
The brush motor went out. Is it possible to buy one and splice it to the existing wires? Where can I buy one? The vacuum is model #409 the number on the dead motor is: DA-20L-2001, 17.5V DC AOM 4293S
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 421A EZ Kleen Bagless Stick Vacuum. Yes, you can replace the power nozzle motor in the head of the Eureka 421A EZ Kleen Bagless Stick Vacuum by either contacting the local vacuum cleaner dealer in your area or to contact the Eureka factory and ask for cust serv or tech support or parts and they will direct you to the correct dept to order the P/N motor so that you can install it and get on with your cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka 2971AV EZ Kleen Bagless Upright Vacuum Logo
56 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
