Question about Fellowes P70CM Shredder
Stripped gear parts info
I have a Ryobi mitre saw EMS 1442L that has a stripped output assembly gear. According the parts listing this part is no longer available. Does any other model part fit this?
it may be worth investigating if later driven and pinion gears will fit the shafts of your unit
It is a way that ryobi has of making older unit obselete
if you research the gears by shaft size , number of teeth diameters thickness etc you may get something but look for matching gears and not just the stripped gear
you may get gears from another manufacturer/model to suit
Dec 13, 2017 | Ryobi Saws
How do I find the part number for the starter gear
Try this site:
http://www.partstree.com/parts/
Get all the info off your equipment (labels or metal tag riveted onto), so you have the info you need to "drill down" through the site to find your particular starter.
Sep 14, 2014 | Garden
If the window motor makes noise but the window doesn't go up or down is it because the window itself is track?
Most likely the plastic part called a Regulator is broken. This part has the teeth that mesh with the gears. The drive gear could also be stripped; you need both parts to be good for a working assembly. If either is broken, you get the problem you have.
A glass shop can do this repair for you. Sometimes depending on the Make of car, there are special sized rivets you need to replace to join the Regulator to the window.
Please rate my info.
Jan 03, 2013 | Cars & Trucks
Model No MH6150MXQ - 0 Turn table will not
Hello- The motor has a plastic gear on the shaft that turns glass tray. These can crack or slip off the shaft and not engage the slots on tray. Check to see if gear is cracked or stripped. It may just be loose. Anyway, this part is less than 10$, so replace if it's bad. Let me know if this solves the problem. Have more info if needed-  Thanks- Ed
Mar 18, 2010 | Ovens
Liftmaster door opener, motor hums but door does not move up or down!
mtr dr gear stripped if you got a sears parts around your part # 41a2817 no grease on gears stripped gear do it your self, instructions in box, or best to pay someone that does it every day... less can of worms...
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but blade does not move. Sounds like gear stripped or maybe clutch slipping.
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Jul 17, 2009 | Remington 111409 - 01 6" Branch Wizard...
NAD 5355 loader not functioning due to stripped gear
Hi ...
Contact NAD parts thru their website.
or
oaktreent.com might have spare parts.
Mar 12, 2009 | NAD C521 CD Player
Looking for a motor for my Starfinder on my Meade 114EQ-DH4
Only Meade will have replacement gears -- they are the only ones who sell these parts. Usually they want you to return the telescope for repair. Call them here:
http://www.meade.com/support/index.html
www.telescopeman.us
www.telescopeman.org
www,telescopeman.info
Jul 05, 2008 | Meade 114EQDH4 (36 x 114mm) Telescope
Stripped gears on the focuser
Meade will not have parts, focusers are always replaced as an entire unit-- but if the mirror is still good you can buy a replacement focuser here:
http://www.telescope.com/Accessories/Telescope-Focusers/pc/3/51.uts
and here:
http://www.optcorp.com/ProductList.aspx?uid=105-175-343
www.telescopeman.us
www.telescopeman.info
Dec 25, 2007 | Meade Optics
Fellowes P70CM Shredder Logo
61 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
