Question about Medal Sports Sport & Outdoor - Others
I need a replacement blower motor for my medal sports air hockey table
Motor is X/Fan model RCH2258S2-C
  • 8 Answers
SOURCE: what is the best air hockey table?
It really depends on what you are looking for: who are the players - young or adults? Do you have money limitations? Do you have space limitations? If you are looking for the nest one, try the Dynamo Hot Flash II Air Hockey Table. Its $3,800. If you want cheaper tables you can go to: http://www.justairhockeytables.com/ and sort them by "best sellers" you'll get the most popular ones.
Posted on Jul 09, 2012
  • 10 Answers
SOURCE: How do I clean my air hockey table?
Air hockey tables can be cleaned with isopropyl and paper towels. Make sure not to use too much at once, and then dry it off with the paper towels, so the alcohol will not soak into the table surface. Note that you should not clean the rails as the dirt inside the rail actually prevent the pucks from flying off the table.
  • 35 Answers
SOURCE: Which Air Hockey table should I buy?
If you want an approved for USAA tournaments then you can check out any of the 8 foot long Dynamo Air Hockey table, just stay away from the "Hot Flash" series.
In the "Hot Flash" Air Hockey tables the painted rails make the puck fly off a lot, and fluorescent table-top makes it hard to see the puck.
A new Dynamo table price varies from $1500 to 2500$ so you should take it into consideration.
Posted on Jul 25, 2012
  • 35 Answers
SOURCE: What's the size of a standard Air Hockey table?
There are many types of Air Hockeytables out there. The usual s of an Air Hockey table shifts between 76-84inch long and 44-52 inch wide, the of the surface is 4 inches less thanthe actual of the whole table.
  • 30 Answers
SOURCE: What's the best air hockey table?
The Valley-Dynamo Hot Flash 2 8 Foot Air Hockey Table is considered to be the best Air Hockey table of all times, this table is the standard table of all the professional tournament although it's price is a bit price if you want to buy it, something like 4000 dollars.
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
How do I find a fan or fan motor for an Emailair air conditioner 110RC Room
you have to find an appliance parts house you can chesk online to you will need serial no. model number. rotation of the motor amps and hp. the best i to take the motor with you
Jul 20, 2014 | Heating & Cooling
Condenser fan motor
It would be easier to get the data from the condenser fan motor than attempt to match AC unit model numbers. If unreadable then remove the fan motor and take to someone to match with the one you have. That is what I do, Thanks Sea Breeze
Make sure you mark your wiring before removal.
Jun 14, 2013 | Intertherm Heating & Cooling
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
I have a kenmore model # 59675522400 The fridge is
Hi and welcome to FixYa, I am Kelly. You have most likely found the problem being the evaporator fan is turning slowly. Most of the time if there is a voltage problem with and evaporator fan they just do not turn at all. I suspect that the fan bearings are dry and the armature is not turing full speed.
Sometimes you can lubricate the motor with a parrifin based oil and revive them. Most of the time on the white motors lubrication does not work as you can only lubricate one of 2 bearings due to the motor design.
Your evaporator fan motor is here: Detailed view
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/Refrigerator-Parts/12002744/0046/464/Model-59675522400/0583/0161000?keySuffixId=NA&productTypeId=0161000&searchModelNumber=59675522400&subCompDesc=Evaporator%20area%20&%20rollers&brandDesc=KENMORE%20ELITE&modelDesc=KENMORE-REFRIGERATOR&blt=11
Component location view: (item 18)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675522400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
All other parts:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675522400/0583/0161000?pathTaken=
The Evvaporator fan motor voltage should be 120 VAC across the 2 fan motor wires.
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Kenmore Refrigerators
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Motor burned out of fan/lighting unit. Old model
dominion electric might have it if you really have to have that fan but best to get new one same work you got to bring it downand work on it ...less work buy new one less head ache ....
Oct 03, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
Jun 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Sport & Outdoor - Others Logo
248 people viewed this question
Top Medal Sports Sport & Outdoor - Others Experts
Bill Eager
Are you a Medal Sports Sport and Outdoor - Other Expert? Answer questions, earn points and help others
