Question about Acer Computers & Internet
I have a user profile logon failure, safe mode not working when I press F8 but makes a loud noise
I have a user profile logon failure & have been advised to press F8 when the computer is logging on to start safe mode and fix the problem. safe mode is not coming on and the pc makes a loud ringing/beeping noise and does not go into safe mode. Any advice?
PauldLucky
  • 268 Answers
SOURCE: User profile cannot be loaded
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
Logon to the Computer
NOTE : Go down the list here until you find a option that will work for you.
1. Logon to another Administrator account.
NOTE: If you do not have another Administrator account, then proceed to step 2.
A) Go to OPTION ONE or OPTION TWO.
2. Boot into Safe Mode.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
C) Go to OPTION ONE or OPTION TWO.
OPTION ONE:
Fix the User Account Profile
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
OPTION TWO:
Delete the User Account Profle
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
1. Delete the User account profile that this error is for.
NOTE: See: How to Delete a User Account in Vista
2. Open the Start menu.
3. In the white line (Start Search) area, type regedit and press Enter.
4. If prompted, click on Continue.
5. In regedit, go to: (See screenshot below step 7)
6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it.
NOTE: It may have .bak at the end of it.
A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.
B) Repeat step 6 until you find the one that you deleted in step 1 above.
NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.
7. To Backup the Registry SID Key -
WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.
A) Right click on the SID key, and click Export.
B) Type in a name and save the REG file to a safe location.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
C) Continue on to step 8.
8. To Delete the Registry SID Key -
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
10. Now, just create a new normal Administrator account.
NOTE: See: How to Create a New User Account in Vista
11. Restart the computer, and logon to your new account.
Good Luck.
Live, Love, Laugh.
Posted on Sep 11, 2008
  • 19 Answers
SOURCE: laptop does not recognize "user Profile" at initial logon
when you are in safemode as administrator you can go to the user section and reset your husbands password. make sure that your caps lock and your numlock is not on. good luck
Posted on Mar 12, 2009
  • 7 Answers
SOURCE: CAN'T LOGON ....SAYING .....THE USER PROFILE SERVICE service failed the logon .user profile cannot be loaded ...never had problem before ...normally type in password and it loads ..
this may be a corrupted file for taht particular user thats causing the problem why cant you try opening the other user profiles or if you cant access that too then try turning on your pc and when the list of user profiles appear press ctrl+alt+delete key in and order but you should keep allthree keys down like how you would keep the shift button down while typing an upper case....now when you press all three down a small dialogue box will appear requesting username and password in the username box type administrator and click login no password required after it logs in create a new profile from the control panel but don't use this user profile again because if this gets corrupted then you would have to format your computer.....formating it will delete all the data stored on your pc.....
Posted on May 16, 2009
  • 71 Answers
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
Posted on Jul 25, 2009
  • 2219 Answers
SOURCE: my acer when I log on says user profile service
use F8 and go into sfae mode, this will load a default profile and will allow you to add a new user (to create a new profile).
Then you can logon in using the new profile.
Posted on Apr 11, 2010
Why can't I access safe mode on my Asus K53U laptop
Your user profile has been deleted or corrupted. See this Microsoft Knowledgebase article You receive The User Profile Service failed the logon error message .
Sep 04, 2014 | ASUS Computers & Internet
Won't login
when your netbook starts up, press f8 and from the following menu, choose to start using safe mode with gui. If you have specified an administrative password at the time of windows installation, use that to log on. If you have not, you should be able to simply log on with the administrative account. Now, go to the control panel>user accounts and create a new user account. Now, you should be able to logon using the new user account. Make this one an administrative/standard account instead of a limited one. When you logon using this account, you should be able to get your data of the previous account from C:\Users\<previous profile name>... You can take backup of this data and then delete the previous user profile to avoid further confusion.
Hope this helps.
Nov 19, 2013 | eMachines eM250-1915 Netbook
Cant login
Restart your computer in safe mode. To do this first power it down wait 10 seconds. Locate the F8 key; press power button an start tapping F8 key. This will bring you to a screen with many options. Choose safe mode. This is a limited mode but many things can be fixed including your profile. Option 1. Go to control panel user accounts. Here you can add an account. Option 2 Delete your account (make sure there is another account you can log into prior to doing this) Go to start->computer right click then click properties. In system properties click advanced tab. Under user profiles click settings. In the User Profiles dialog box, select the profile that you want to delete, click Delete, and then click OK. Click Start, type regedit in the Search box, and then press ENTER. Locate and then click the following registry subkey:
    1. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
      Right-click the SID that you want to remove, and then click Delete.
  1. Log on to the computer and create a new profile.
  2. Hope this info helps.
Apr 27, 2013 | Acer Computers & Internet
On booting up my Inspiron mini 1012 netbook it keeps displaying 'the user profile service failed the logon' and 'user profile cannot be loaded'
Try logging in on the admin acct then delete and recreate the profile. If it doesn't work you can try switching off the comp then continously press F8 while turning on the comp and choose safe mode, then do a system restore.
Mar 18, 2011 | Dell Inspiron Mini 1012 Netbook...
When I type in my password it says user profile service failed the login user profile cannot be loaded
Log on computer in safe Mode by pressing F8 Key when computer start and logon to administrator account after then create a new account and make him administrator and now restart your computer then logon by new account
After then copy your old account data from user folder/old username/desktop and my documents etc. to your new account.
Jan 01, 2011 | Packard Bell EasyNote A7 718 Notebook
My laptop keeps displaying the user profile. Service failed the logon. User profile cannot be loaded.
Restart your computer press F8 right after the First Boot screen and Select Safe Mode Windows. Delete that User or make a New User Profile. That must fix your problem if your Safe mode is not secured by password, or if it is then consider reinstalling Windows.
Thank for asking Sir !
Dec 15, 2010 | Computers & Internet
When i open my computer theres an error the user profile service failed to logon user profile cannot be loaded
Logon in safe mode.
  • Restart your computer and log into safe mode: As your computer is rebooting, press F8 Repeatedly after your POST screen.
  • Choose safe mode with networking
  • Open internet explorer and copy and paste this site into the address bar:
http://www.thewindowsclub.com/fix-the-user-profile-service-failed-the-logon-user-profile-cannot-be-loaded
  • Click on Microsoft Fixit.
If this resolves your issue, 4 thumbs would be appreciated.
Sep 16, 2010 | Computers & Internet
L350-170 Logon Failure
Sounds like profile corruption or virus problem. Try restarting the machine and tapping f8 until menu appears. Go into safe mode then logon as administrator. If you can get into windows, go to control panel then user accounts. Create new user account then restart machine. Log on using new user account and copy all personal files/folders to new user account.
Apr 08, 2009 | Toshiba Satellite M45-S2652 Notebook
Computers & Internet Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
