Question about Frigidaire Microwave Ovens
Lock flashes on and off
This is for model FFMV164LSA. Roommate was warming some coffee and when she took it out the lock icon started turning off an on. No buttons work, unplugging it for several minutes and plugging back in does not fix it. Tried holding down Stop/Cancel for 3 or more seconds and nothing happens. Just the icon flashing on and off and a beep that accompanies the flashing. The microwave is currently not useable and we've only had it for several months.
MicrowaveSvc
  • 9098 Answers
SOURCE: Micro beeps 3 times with "F3" flashing on LCD screen. Nothing works.
If it's a GE model, F3 will mean a shorted key panel.
(If it's not a GE, please reply back with your brand and model number so we can help you).
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 29, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I cooked a frozen breakfast
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Doorswitch or mount trouble can be caused by slamming the door or byopening the door while it's cooking without hitting the Stop pad first.
Thereare plastic mounts inside the microwave which hold the door switchesand onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimesit's a broken tab on the switch holder, allowing the switch to rotatejust out of position. Other times, it's a broken tab on the switchholder, allowing the switch to rotate just out of position. This tabcan be hard to see, since it is under the bottom edge of the switch.
Ifyou or someone you know decide to look into it, we have criticalinformation on safety, disassembly and door switches at our site, andour link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Jul 13, 2008
SOURCE: sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Posted on Aug 08, 2009
SOURCE: Have a new Emerson MW9710W microwave. Had it
My daughter is having the same problem as you are having. Thing is we bought it for her new. She had not used it at all for a year. They finally bought a house, started using it in May. It is now doing the exact things yours is doing. Is there some kind of recall notice on these microwaves or what is wrong and how do we fix it?
Posted on Aug 28, 2010
  • 4 Answers
SOURCE: KitchenAid built in microwave model #KHMS155LSS-4.
Whirlpool is conducting a safety recall on the Kitchenaid KHMS155L series (and similar models under other brand names) that display the F2 code or have been observed self-starting. Other symptoms may be additional codes or unintelligible info being displayed, and failure to execute the command entered into the control pad. To obtain free replacement of the control panel, call Ava at Whirlpool: 1-866-640-7146, extension 6337. She will want your complete model and serial numbers and a phone number and address where you can be reached. She will arrange for A & E Factory Service to contact you to set up an appointment to come out and replace the control panel at no cost to you.
Posted on Nov 02, 2010
Frigidaire microwave model ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep.
Hopefully no one sprayed a liquid cleaner directly onto or near the keypad...
From page 23 of the owner's manual:
"Wipe the microwave oven inside and out with a soft cloth and and warm (not hot) mild detergent solution. Then rinse and wipe completely dry."
"Clean the outside surface of the microwave with soap and a clean damp cloth. Dry with a clean soft cloth. To prevent damage to the operating parts of the oven, do not let water seep into any vents or openings."
If there is moisture damage, it may dry out by itself if you leave it overnight with the door open. If not, the warranty would be voided and you'd have to arrange for out of warranty service.
If there is no moisture damage, and it failed not due to outside forces, then you should contact the manufacturer to arrange warranty service.
Oct 05, 2016 | Frigidaire Over-the-Range Microwave
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
Unlock frigidaire microwave model FFMV164LSA
Good Afternoon Friend,
I understand you are trying to unlock your Frigidaire microwave, model# FFMV164LSA. This has two different meanings to me. First, if the door is locked and will not come open, I suggest contacting your local authorized technician. Secondly, the control lock is on. If the control lock is on, you will need to press and hold down the "Stop/Cancel" button for 3-5 seconds, to unlock it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FMT118E1W Microwave Oven
No power
I am having the same problem with mine. Had a burning smell when I used it and then no power. Was hoping it was just the main fuse, but it sounds like it could be something else. This microwave only lasted two months out of warranty. A $500 major purchase mistake! :-(
Nov 29, 2013 | Frigidaire Microwave Ovens
Roommate steamed up the spacemaker by hard boiling pot of soup without running the fan. Then microwaved a cup of coffee while the steamed condition was still present. An arc sparked from the vent above...
Sounds like a problem in the high voltage side. Need to check the diode and if good the voltage at the magnetron. Should be 3.5 volts across mag and 4500 dc volts at mag. If you do not have a meter to check replace both mag and diode aprox $150.00 from GE. Pat
Dec 03, 2010 | GE Microwave Ovens
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Microwave stopped heating
With the symptoms you have, I would most strongly suspect a blown high voltage rectifier diode.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number at the Sears parts site.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Jan 11, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
