Question about Bernina Sewing Machines
Bernina Matic (801) begun to skip stitches -
At first the bulky bits of fabric (at seams) would jam, odd broken needle etc then suddenly not picking up bottom feed properly, plus needle jamming in top. Tension wheel seems to jam by itself even after releasing it.
  • 323 Answers
SOURCE: i have an 1130 bernina
The 1130 does not have a consumer adjustable presser foot. Check to be sure you are using the correct presser foot .Some feet are slightly different in height which is how the pressure is regulated. If this is not your problem it will need to be seen by a technician.
sewman7
Posted on Jul 14, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
  • 1116 Answers
SOURCE: bobbin thread showing on top, automatic tension
It is possible the jam threw off the timing and this will need to be fixed by a sewing machine tech.
Try one more thing first. Lift the presser foot - this will open the tension control so the thread can properly seat into the control.
Re-thread the machine.
If this does not help, back to suggestion # 1.
Posted on Mar 25, 2010
  • 17 Answers
SOURCE: The bottom thread on my Bernina 140 jams
Try pulling more thread out before you begin the seam - about 6". If you can hold the threads while you take the first few stitches that helps too.
Posted on Aug 15, 2010
SOURCE: Elna 2007 making clicking noise - My elna is
it needs to be repair or traded in for a new machine
Posted on Nov 03, 2010
My Bernina 830 is skipping stitches when I try to sew on Scuba (knit) fabric
Most likely it is a needle issue--incompatibility with the fabric being sewn. You might try changing the type of needle--you may have to do a trial and error. Usually, ball-point needles are for knit fabrics, but your scuba fabric is probably pretty dense so you may need to try a sharp needle like a microtex.
All About Needles
Apr 01, 2017 | Bernina Sewing Machines
I have a Bernina 1090 S and on straight stitch it does not stitch straight and on zig zag it is also crooked. I've changed needles, thread, bobbins, cleaned out the entire bobbin case compartment. Please...
what do you mean by crooked? If skipping stitches, you have the wrong needle. Stretch fabrics use a "BALL POINT" needle. Woven fabric uses a "SHARP POINT" needle. They are not interchangeable. Another "under known" issue, if you needle has more than 50 hours of use, it will cause various issues. Don't be afraid to throw away a perfectly good looking needle...good looks aren't always useful!
Oct 29, 2013 | Bernina Sewing Machines
Bernina 820, quilting with the BSR foot, my machine will sometimes skip 1 to 4 stitches after going over a seam, help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 27, 2013 | Sewing Machines
Machine skips stitches on bulky items
Skipped stitches
Aug 19, 2013 | Simplicity Quilter's Classic SW240...
The cotton on my bernina 801 keeps jamming
Loops on bottom indicate a top thread tension problem.
Make sure needle is the correct size and not bent or broken
Make sure it is threaded properly with the lever UP.
Do a test stitch.
If it still loops below... tighten the top tension and do another test stitch... keep doing this until the stitch is balanced.
BTW... always grasp and hold both threads when starting a seam.
Jul 30, 2012 | Sewing Machines
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Sewing machine no movement
I know what the problem is. Its a cracked gear. When you have the top open look at the big fiber gear on top. It is common for these to crack and now it is stuck. Needs a Bernina service guy to replace it. There is one more smaller fiber gear near the handwheel inside that could be cracked also.
Aug 27, 2009 | Bernina Artista 180
Bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Mar 14, 2008 | Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
