Question about GE Profile JT952 Electric Double Oven
CharlieHutchipop@yahoo.com/solution for the Dreaded "F7" Error
I continue to get F7 on my stove panel. I have turned off all power pulled out the plug it stay off but still come back. What can I do, please help.
Powerman
  • 68 Answers
SOURCE: F7 error code
Hi Kathryn, I believe that I have already sent you my solution via another route. Hope you received it. Basicaly for anyone else with this problem, it is caused by a short circuit envolving the ribbon cable which connects the touchpanel to the electronic control. The solution varies slightly depending on whether you have a metal or plastic touch panel. If you have a plastic touch panel,you need to add some extra insulation between the two pieces of ribbon cable in the slot where it exits the touchpanel. You need to slip it down as far into the slot as it will go. A piece of paper, a piece of file card, a thin piece of mylar will all work just fine. If you have a metal touchpanel, you need to insulate the edges of the slot as well with paper or mylar. Insulate both edges. If you don't have two sections to the ribbon cable, obviously you can't put insulation between the sections. If you have a plastic touch panel and only one section to the ribbon, you are out of luck. There is nothing you can do except to purchase a new touch panel. Cleaning the contacts is a myth. It doesn't help. Hope this helps. Please let me know your results. Contact me at hutchipop@yahoo.com. Regards, Charlie
Posted on May 09, 2007
Powerman
  • 68 Answers
Hi dadcandoo,
You can find my solution for the most common cause of the F7 problem at the following links:
http://www.fixya.com/howto/h155060-dreaded_f7_error
or
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have now shared my fix with over 1700 folks and most report success. It is simple and free. I hope that it works for you too. Please let me know at hutchipop@yahoo.com. Also, what is your model number, how old is your oven and where are you located? I am making a statistical study of this problem.
Regards,
Charlie Popeck, P.E.
Consulting Enginner
Posted on May 09, 2008
  • 4 Answers
SOURCE: GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Posted on Aug 02, 2008
aborcass
  • 2651 Answers
SOURCE: f7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Posted on Nov 17, 2008
SOURCE: GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Posted on Jan 22, 2009
I am getting a F7 on the display and nothing will work other than the clock.
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 31, 2009 | GE Ovens
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Jul 30, 2009 | GE JTP20 Electric Single Oven
We are getting an F7 code on our display ..What is this?
Jun 07, 2009 | GE JRS06 Electric Single Oven
F7 keeping flashing on my oven
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem so far.
Nov 12, 2008 | GE JKP28 Electric Double Oven
Time flashes ...No other electronic button function
You may have the dreaded F7 problem. Go to the following link:
Please let me know if this works for you. I have shared this fix with over 1600 folks and most report success. You can email me at hutchipop@yahoo.com
Regards,
Consulting Engineer
Mar 09, 2008 | GE JRS04 Electric Single Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
GE Profile Spectra Electric Oven Self clean malfunction and F7 error
I can't help with the burn marks, but have considerable experience with the F7 problem. Click on the following link for my solution:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success. Please let me know if this works for you.
Nov 21, 2007 | Ovens
Error message...
The F7 is intended to indicate a stuck START key. However, a design defect may cause a false indication. This can be corrected by adding insulation to the ribbon cable. You can find detailed instructions at my web site. Follow this link:
All of the above must be entered as the address on the same line.
I have now shared my solution with over 1350 folks and most report success. It is simple and free. Please let me know if it works for you too. You can contact me hutchipop@yahoo.com
Nov 01, 2007 | GE JRS04 Electric Single Oven
Upper Over Touch Pad dead
This may be related to the F7 error problem. I have posted the solution to that problem on this website. Do a search on "Dreaded F7 Problem" and you should be able to open the link. If that doesn't work for you, email at: Hutchipop@yahoo.com and I will send you the solution. Regards, Charlie Popeck, P.E. Consulting Engineer
Aug 21, 2007 | GE JKP27 Electric Double Oven
F7 error code
May 08, 2007 | GE Profile JT910SASS Electric Single Oven
GE Profile JT952 Electric Double Oven Logo
71 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
